Pipe flow developing too quickly
Old   January 7, 2013, 05:09
Default Pipe flow developing too quickly
qrie is on a distinguished road
I am simulating the development of a pipe flow. At the inlet, uniform velocity is imposed and it reaches a parabolic profile somewhere downstream and becomes fully developed. My problem, however, is that, the location at which it reaches the parabolic profile is too close to the inlet (on comparing with results from journal papers). Any suggestions on why this might be happening?
Thanks in advance,
Qrie
qrie is offline   Reply With Quote
Old   January 7, 2013, 05:36
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Originally Posted by qrie View Post
Thanks in advance,
Qrie
what about your Reynolds number?
FMDenaro is offline   Reply With Quote
Old   January 7, 2013, 06:04
I have tried it for Re 10 and 100. Encountered the same problem in both cases.
Old   January 7, 2013, 06:43
you get the same lenght x/D both at Re=10 and Re=100? Are you sure that the solution corresponds to the analytical parabolic velocity profile?
Old   January 7, 2013, 06:47
I meant I get fully developed profiles much earlier in both cases compared to the respective values in the journal paper. Yes, the solution matches the Poiseuille parabolic profile.
Old   January 7, 2013, 07:30
And I checked now, and turns out - yes for both I get it at the same x/D!
Old   January 7, 2013, 07:41
of course something wrong must be in the code... check in the code the actual value used for the Re number, try also if Re=500 gives you again the same x/D value ... what about the outflow BC?
Old   January 7, 2013, 07:43
Ok, will do that. I have given convective outflow bcs.
Old   January 7, 2013, 08:00
Assuming that the code has no bug, what about the grid sizes and discretization of the convective terms? If your grid is too coarse and you are using first order upwind, maybe you have so much artificial viscosity that overcome the real one... but I am more for some bug ...
Old   January 7, 2013, 08:06
The code uses second order central differences, and isn't coarse. I have refined it to the same size as in the paper. Its a direct solver, no artificial viscosity is used. Thanks, I will check for any bugs. Have already done that actually. Is there anything else that might be causing this?
Old   January 7, 2013, 10:49
I have no other idea than checking for some bug in the input data... maybe somehow the value of the Re number is fixed to a small value...check also for the divergence of the velocity if is zero everywhere
Old   January 8, 2013, 04:30
Yeah velocity is not diverging, however if I increase the pipe length too much it does.
development length, pipe flow
[ASK] Flow in Corrugated Pipe with FLUENT Primadhani FLUENT 1 May 11, 2011 20:41
Pipe Flow Saima CFX 1 January 10, 2011 16:41
flow in perforated pipe distributor pertupd ANSYS 0 August 12, 2009 08:36
outlet boudary condition for a flow in the pipe Atit CFX 2 November 9, 2004 17:43
stepped pipe flow Tom Cloutier Main CFD Forum 0 April 20, 2003 13:19
