solving airfoil like square cylinder problem?
Old   May 27, 2006, 07:50
Default solving airfoil like square cylinder problem?
zonexo
hi,
i had used a structured FVM NS solver to solve for flow past a square cylinder. actually, everything is solved using cartesian grid, with the square cylinder (consists of e.g. 16 cells) at the center blanked out. hence, although it's a structured solver, the problem simplifies to a cartesian problem.
The solution compare ok.
now i've generated a structured grid with edges of the quadrileterals forming an airfoil shape. hence, if like the square cylinder whereby some cells are blank out, it becomes an airfoil at the center.
can this be used to solve flow past an airfoil? i've tried and the velocity are wrong. i wonder if it's my mistake or there's some fault with this implementation.
hope someone can give some advice. thanks!
Old   May 27, 2006, 15:16
Default Re: solving airfoil like square cylinder problem?
Bounecer
Do you have used C-grid generation, and do you have used a good stretching parameters
Problem running buoyantFoam anke OpenFOAM 4 August 28, 2013 04:43
Low Mach number Compressible jet flow using LES ankgupta8um OpenFOAM Running, Solving & CFD 7 January 15, 2011 13:38
lift and drag on ship superstructures vaina74 OpenFOAM Running, Solving & CFD 3 June 8, 2010 12:30
Problems with simulating TurbFOAM barath.ezhilan OpenFOAM 13 July 16, 2009 05:55
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 11:16
