December 4, 2006, 09:06 |
unsteady RANS-flow around cylinder
Hi there,
our finite element based flow solver was extended with high-reynolds k-epsilon model which was later modified with Chien's low-reynlods model. It was also succesfully tested on a benchmark problem of channel flow and backward facing step. My aim is to simulate flow around cylinder at Re=10000. I know, that there is a problem with Chien's model to predict separation and reattachment, for this reason the friction velocity has an alternative scale, which is widely used in CFD (u_tau=srt{sqrt(c_mu)*k}), but the behaviour of the flow is still not what the experiments predict, because the solution is oscillation free (i.e. no vortex shedding is present). Do You know, if Chien's model is usable or not in this case, and if not what kind of model should I use? In fact I do not think, that I have problems with the resolution of the mesh, because y+ varies around the cylinder in a range of 0.1-0.4. thanks, otto |
flow over a cylinder urgent! | kevin | FLUENT | 8 | August 11, 2015 13:00 |
Incorrect Drag and Drag Coefficient for flow over a cylinder | ozzythewise | Main CFD Forum | 8 | June 13, 2012 06:24 |
how to predict unsteady flow from case definition? | Felix | Main CFD Forum | 6 | August 28, 2007 16:40 |
flow around circular cylinder...plz help | yousef | FLUENT | 4 | March 28, 2006 11:01 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
