vortex length scale
Old   March 16, 2006, 11:49
Default vortex length scale
ZubenUbi
hello,
Does anybody knows how to calculate an average length scale of a vortex flow.
I mean, if you look at a flow behind a cylinder at low Reynolds number, you find an alley of vortices. Using a ruler, it is really easy to measure their radius. But how should I do if I can not or don't want to use a plan cutter ?
Of course, if the center of the vortex is known then the radius can be computed from velocity spatial cross correlation. But how should I do if I don't know where the center is ?
Thanks in advance for your answer, if any,
ZubenUbi
Old   January 19, 2014, 07:28
Smile
LouisK
kangluyang is on a distinguished road
I have come across the same question, based on my calculation results, the velocity in the end of vortex is the lowest, so the distance between the two lowest velocity is vortex length, but do you have some reference papers for this method?
kangluyang is offline   Reply With Quote
Old   January 19, 2014, 07:45
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
but the first issue is: how do you detect a vortex? Many methods can be used and can produce different results...
FMDenaro is offline   Reply With Quote
Old   January 19, 2014, 07:51
LouisK
I have gained the friction velocities around the gable roof. According to the streamline and the results of velocities, i think the vortex end velocity is the lowest, so the length between the two lowest velocities is the length of a vortex, but is there some reference for this method?
Old   January 19, 2014, 13:22
Joachim
Joachim is on a distinguished road
Hey!
You could use the vortex detection scheme of Graftieaux I guess.
Graftieaux, L., Michard, M., and Grosjean, N., \Combining PIV, POD and Vortex Identi cation Algorithms for the Study of Unsteady Turbulent Swirling Flows," Measurement Science and Technology, Vol. 12, No. 9, August 2001, pp. 1422-1429.
Good luck!
Joachim
Joachim is offline   Reply With Quote
Old   January 19, 2014, 21:59
LouisK
Originally Posted by Joachim View Post
Hey!
Good luck!
Joachim
Thank you! I have read this paper in the morning, it really helps about the concept of vortex length and center.
However, it does not solve my problem. I have gained the RANS results of a flow field by CFD, then I want to estimate the time averaged mean eddy length in an easy way without fluctuating velocities. The main purpose for me is to determine the influence length of a separation bubble on the wall.
Old   January 20, 2014, 01:23
LouisK
However, it does not solve my problem. I have gained the RANS results of a flow field by CFD, then I want to estimate the time averaged mean eddy length in an easy way without fluctuating velocities. The main purpose for me is to determine the influence length of a separation bubble on the roof.
Kang Luyang
Turbulence length scale and integral length scale rizhang CFX 2 April 22, 2016 07:22
Integral Length Scale vs Turbulent Length Scale Scott Nordsen FLUENT 2 January 20, 2014 01:17
Turbulent Characteristic Length/Turbulent Length Scale fluentnoob FLUENT 2 July 3, 2009 08:40
LES inlet length scale f.neilson Main CFD Forum 0 January 31, 2005 13:26
