February 22, 2014, 13:00 |
Flow in a Pipe
Rep Power: 13 |
Hi
I'm simulating the flow through a Pipe in 3d. The fluid is water. Boundary conditions are velocity inlet at the inlet, constant flux for the wall and outflow for the outlet. simulation for momentum equation works fine but it seems there is no change in temperature. temperature inside Pipe is constant and equal to temperature at inlet (300k). Averaged nuslet number doesn't match with the experimental equations. can anybody help me? thanks |
February 24, 2014, 04:02 |
Simas
Rep Power: 14 |
Firstly make sure that setting up in BC you didn't made any mistake. I would suggest trying to increase heat flux. If you have 100 make it bigger like 1000 or 10000 and check if the outflow temperature will change.
February 24, 2014, 14:38 |
Rep Power: 13 |
I increased heat flux and it worked. Thank you very much.
LES transitional pipe entrance flow | hasanduz | Main CFD Forum | 2 | October 11, 2013 17:59 |
HTC in Pipe flow | subsemitonium | CFX | 6 | May 6, 2013 22:00 |
[GAMBIT] meshing in GAMBIT, a flow through a pipe having complex inflow geometry | mazhar1613 | ANSYS Meshing & Geometry | 1 | January 11, 2012 23:18 |
[ASK] Flow in Corrugated Pipe with FLUENT | Primadhani | FLUENT | 1 | May 11, 2011 20:41 |
Pipe Flow | Saima | CFX | 1 | January 10, 2011 16:41 |
