exporting STL from Hypermesh to 3-matic
Old   November 29, 2012, 00:32
Default exporting STL from Hypermesh to 3-matic
dirty trucker
jdwarren is on a distinguished road
Greetings. I am attempting to export a mesh consisting of 2D triangular elements in STL/ASCII format in Hypermesh 11.0 (for use in 3-matic). Every time I attempt the export, I get the attached error message.
The number of elements "not defined in the template" (244684) is the total number of elements in the model. Does anyone have any familiarity with this sort of error message?
Thanks in advance.
jdwarren is offline   Reply With Quote
Old   January 9, 2015, 05:04
Saiteja
saitej09 is on a distinguished road
Hi
Was your problem solved ? I am actually facing the same problem when I am exporting to stl file
saitej09 is offline   Reply With Quote
Old   January 9, 2015, 13:31
dirty trucker
The problem is that the elements were second order (quadratic). A simple "order change" should resolve your issue.
exporting, hypermesh, stl format, template errors
Hypermesh Exporting eishinsnsayshin FLUENT 8 November 29, 2012 00:29
Hypermesh Exporting eishinsnsayshin ANSYS 0 April 3, 2012 18:16
Exporting mesh from FLUENT to HYPERMESH or LS-DYNA Subramani Sockalingam Main CFD Forum 3 February 19, 2008 07:34
Exporting mesh from FLUENT to HYPERMESH or LS-DYNA Subramani Sockalingam FLUENT 1 February 4, 2008 04:27
Exporting HyperMesh file to fluent 5 Ricardo FLUENT 0 July 6, 2000 04:18
