Quantum electrodynamic explanation of turbulence |
September 28, 2014, 09:26 |
bilal
Rep Power: 11 |
I was reading this book by Richard Feynman (6 easy pieces) in which he said that turbulence is one of the unsolved problems of classical mechanics. So has any scientist ever tried to develop a quantum theory in order to explain turbulence?
September 28, 2014, 13:00 |
I think that, when referring to "one of the unsolved problems in classical mechanics", it is usually intended that the "mathematical problem known as 3D Navier-Stokes equations" still lacks a proof of existence and unicity (or lack of) for a solution under all but the most trivial circumstances (ridicolously low Re numbers and simple b.c. settings).
Moreover, while the physics of fluids in general is well understood (conservation of mass, momentum, etc.), specific flow mechanisms at play in specific settings may actually not and, again, besides the most trivial cases, we need expeirments (physical or numerical) to investigate them. Among these, i can rememeber of cases where the quantum nature of the matter assumes a relevant role. Try, maybe, looking in the book of Landau and Lifshitz (the first guess coming to my mind). In conclusion, it is not the fluid mechanics formulation of the turbulence the real problem (as numerical simulation based on the classical Navier-Stokes equations are known to fit the experimental evidence) as much as understanding the problem itself in the present formulation. Navier-stokes equations are already derived from particle theories without problems and i don't think that going down toward more fundamental physics aspects would add anything new. Of course, this does not exclude tha a talented physician might see something in the fluid mechanics problem expressed at the quantum level which is instead not as much clear at the "classical level". |
September 28, 2014, 22:33 |
#3 | |
You can see eg related works of this guy http://www.princeton.edu/physics/peo...netid=polyakov or this guy https://www.weizmann.ac.il/home/fnfal/ Also there were a lot of work on renormalization group and turbulence in different dimensions (starting from burgers turbulence in 1d up to conventional 3d) etc. |
Turbulence length scale | Leonpolou | FLUENT | 2 | January 23, 2013 07:26 |
Wrong calculation of nut in the kOmegaSST turbulence model | FelixL | OpenFOAM Bugs | 27 | March 27, 2012 09:02 |
Explanation for terms like RAS turbulence, kEpsilon,... | tH3f0rC3 | OpenFOAM Pre-Processing | 2 | March 16, 2011 09:16 |
How's going on with Turbulence Research? | Daniel | Main CFD Forum | 1 | June 20, 2008 23:44 |
turbulence modeling questions | llowen | Main CFD Forum | 3 | September 11, 1998 04:24 |
