grid around an airfoil
Old   January 31, 2008, 13:44
Default grid around an airfoil
mr. flow
I need to generate H-grid type around an airfoil in ICEM. I am not sure how should i put blocking around my airfoil. Can anyone help me with that please. Thanks in advance.
mr. flow
Old   February 1, 2008, 04:09
Default Re: grid around an airfoil
Charles
Unless it's an airfoil with a sharp leading edge, I'm not sure that an H-grid is the right way to do this? A C-grid embedded in an H-grid is more likely to work. To do this you basically have to split the main block into nine small ones, delete (move to VORFN) the one in the middle, and build a C-topology in its place.
Old   February 1, 2008, 17:03
mr.flow
Hi charles
Thank you for your answer. Its really hard for me concieve which nine blocks and at what locations you are referring to. Can i have a look at any of the airfoil that you might have meshed.
Thank you again
Help! Validity of unstructured grid on S809 airfoil didiean FLUENT 11 April 3, 2011 02:10
Grid generation of an airfoil in Ansys workbench 12.1 sunish5 ANSYS 1 October 26, 2010 23:29
2D airfoil simulation, turbulence, boundary layer, unstructured grid louis.langouche@gmail.com FLUENT 0 March 3, 2010 08:19
Structured Airfoil Grid Generator A.S. Main CFD Forum 1 September 30, 2008 18:29
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 05:59
