VOF single bubble rising velocity!
Old   May 19, 2008, 22:03
Default VOF single bubble rising velocity!
Lincoln
Hi, everyone on CFD forum:
Recently, I'm simulating a single gas bubble rising in infinite stagnant water using FLUENT, as you know, 3D VOF is very time consuming, so can anyone give me some advise on this subject and specificly how can I judge the convergence and how can I know the rising volecity of bubble (i.e. how can I know the centroid of bubble) in FLUENT VOF unsteady simulation. Thanks for your reply in advance!
Lincoln
Old   May 19, 2008, 22:29
Default Re: VOF single bubble rising velocity!
Lincoln
at First, I create a Isosurface vof=0.5 and get the centroid of the bubble through surface integrals panel Area Weighted of Average Grid X/Y Coordinate without an air layer at the top of the water pool, but when I add an air layer at the top, I just can not get the centroid using the method mentioned above, so can anyone help me for that!
Old   May 19, 2008, 23:04
Lincoln
AND can I use the Dynamic Gradient Adaption in FLUENT VOF unsteady simulation to refine the interface mesh every time step when coarse mesh is used to reduce caculation time.
Old   April 10, 2012, 10:04
chemengia is on a distinguished road
Hello!
I face the same problem did you solve your question?
Thank you!!
chemengia is offline   Reply With Quote
bubble rising problem swamysrikanth ANSYS Meshing & Geometry 3 May 31, 2016 11:09
Bubble coulmn and VOF method (interFoam) voingiappone OpenFOAM 14 June 26, 2012 20:13
bubble rising in a column swamysrikanth Main CFD Forum 2 September 27, 2010 08:59
hwo to model rising bubble interact with wall Dusky.He Main CFD Forum 2 December 19, 2005 08:53
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
