Software for Wind Field Simulation based on LiDAR data around Wind Turbines
Old   July 14, 2015, 05:42
Default Software for Wind Field Simulation based on LiDAR data around Wind Turbines
David Ebner
davidebner is on a distinguished road
Hey everyone!
First of all I have to admit I am totally new to CFD. I am currently doing an internship at an energy company and dealing with following problem:
We have measured wind velocity data with lidar measurements at a distance of about 300 meters in front of the wind turbine. The data was measured by ground based lidar (giving vertical velocity profile) and nacelle based lidar (giving a horizontal velocity profile in a layer of the nacelle). Based on this velocity profiles we want to simulate the wind flow up to the turbine and the turbulances beyond it and calculate the power inflow in the rotor area plane etc.
Can you recommend a program that is well suited for importing the velocity profiles as boundary conditions and calculate the following wind field?
Is OpenFOAM suited for this kind of simulation?
Best Regards!
davidebner is offline   Reply With Quote
Old   July 19, 2015, 22:28
N/A
harishg is on a distinguished road
You can try the NREL preprocessor TurbSim (https://nwtc.nrel.gov/TurbSim). We have used it for generation of the velocity fields. Once you have the unsteady inflow field generated, you can use the NREL Actuator Line Solver written in OpenFOAM SOWFA to get the wake info and other details.
harishg is offline   Reply With Quote
field, lidar, turbine, wind
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 58 December 23, 2021 02:36
Problem in sampling data of custom field function in ANSYS FLUENT v14 apek_great ANSYS 1 February 26, 2014 05:10
DOLFYN software for CFD simulation in association with Sofistik software! Kshama Main CFD Forum 0 June 28, 2013 00:38
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 17:27
Seeking for flow field (vector plot) visualization software. Hua Main CFD Forum 7 January 25, 1999 11:33
