Y+ Range for RNGk-epsilon Turbulence Method
Old   December 31, 2008, 04:05
Default Y+ Range for RNGk-epsilon Turbulence Method
Velan
Hi all
I simulated fully supersonic flow of scramjet inlet along with cowl using openFOAM. I used RNGk-epsilon Turbulence Method to compute turbulence. My freestream mach number is in the range of 2-3. When i checked the y+ range, it came in the range of 10-600. Near the separation region y+ is very high. I dont know what range of y+ should be for RNGk-epsilon method. Can you please tell me how to calculate y+ ? Does anybody having idea about it ?
- Velan
Old   January 6, 2009, 10:50
Default Re: Y+ Range for RNGk-epsilon Turbulence Method
John S.
K-epsilon models typically need a y+ of around 30 to be accurate as you're not trying to resolve the boundary layer. There's a lot of information about y+ located in the wiki. I find it a little odd, though, that you're reporting high y+ near a separated region inthat y+ is directly related to wall shear. Areas of low wallshear, such as within a separated region, typically have low y+ values.
Is turbulence disripable by chaos? Matthias Main CFD Forum 9 March 27, 2001 13:04
Renormalization Group Method in Turbulence Model wood Main CFD Forum 2 January 10, 2000 19:15
Turbulence by using MAC method Valdemir G. Ferreira Main CFD Forum 0 November 20, 1999 09:33
Multigrid Method in Turbulence Modelling Bipin Lokhande Main CFD Forum 1 November 11, 1998 19:20
turbulence modeling questions llowen Main CFD Forum 3 September 11, 1998 04:24
