Static Pressure Question
Old   October 29, 2015, 19:10
Default Static Pressure Question
Xuekun Lu
Xuekun is on a distinguished road
I am modelling a laminar incompressible flow in the S pipe. The inlet velocity is quite small, generating Re=500, pressure outlet = 1 atm. Initial condition is P=1 atm. Why the static pressure is larger at the inlet than the outlet? Is this because the velocity at inlet is lower than outlet so Bernoulli's equation calculated a larger static pressure? Is my understanding correct?
The pressures I defined in the beginning is the static pressure or total pressure?
I need your help ! Thanks !
[IMG][/IMG]
[IMG][/IMG]
Xuekun is offline   Reply With Quote
Old   October 30, 2015, 15:04
Sarang
Sarang V is on a distinguished road
If you are specifying velocity at the inlet and a static pressure at the outlet then then I would expect the static pressure to be high to drive the flow through the outlet.
Sarang V is offline   Reply With Quote
Old   October 30, 2015, 16:25
Xuekun Lu
Hi, thanks a lot for your reply. I just wander how the solver calculate the static pressure higher at inlet than outlet since I define the initial condition is 1 atm, same as outlet. Is this 1 atm the static or total pressure?
Old   November 2, 2015, 10:49
Sarang
As you said it is just an initial condition. Your initial conditions gets washed way as your simulation progresses. Initial conditions should not affect your end solution for a continuous flow problem (You might get convergence issues if they are set really bad).
Old   November 2, 2015, 17:24
Matt
fluid23 is on a distinguished road
you must have a pressure gradient to have velocity (i.e. flow).
fluid23 is offline   Reply With Quote
bernoulli's equation, pressure, pressure and velocity, static pressure
Wind tunnel Boundary Conditions in Fluent metmet FLUENT 6 October 30, 2019 12:23
Pressure Outlet Guage pressure Mohsin FLUENT 36 April 29, 2016 17:16
static vs. total pressure auf dem feld FLUENT 17 February 26, 2016 13:04
Overshooting static pressure guns_down FLUENT 0 March 18, 2014 01:19
UDF to control Static Pressure (in cylinder) James FLUENT 0 July 20, 2004 07:54
