December 18, 2015, 11:40 |
negative displacement thickness
robo
Rep Power: 13 |
Hi all,
I'm working on an incompressible axisymmetric boundary layer code for some bodies of revolution. For some of my results in turbulent flow, I'm getting negative values for the displacement and momentum thicknesses. The rest of the flow field looks correct, and the code appears to be functioning properly in other cases and validated well for flat plate flow and laminar axisymmetric flows. I'm not sure if these negative values are physical, and if they are, how to interpret them. I've done a bit of googling and it seems like they might be indicative of strong streamline convergence leading to an excess of mass and momentum flow in some region or somesuch but I'm not 100% on that. Can these values be negative? What is the best way to interpret that result physically if they can? Finally, are there any good references on this? I'm using Schlichting's and White's books, but haven't been able to find any references in there to negative values for these parameters, at least not so far. Thanks! |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
[snappyHexMesh] determining displacement for added points | CFDnewbie147 | OpenFOAM Meshing & Mesh Conversion | 1 | October 22, 2013 09:53 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
