January 8, 2016, 15:22 |
Turbulence models k-epsilon k-omega sst
Rich
Rep Power: 11 |
Hi, I am using ansys cfx. Now I want to know in general how the two equation models work, especially the k-e model, because this is used often.
January 14, 2016, 05:18 |
david
Rep Power: 13 |
firstly, k=1/2(u_i'u_i') and not k= 1/2 u_i'u_j'.
Pertaining to your first question, yes. The transport equation solves for the scalars they transport which in your case is k, epsilon or omega. If you look at the raw RANS equations, you realize that the Reynolds stresses are on the right hand side of the equations together with pressure and viscous diffusion. The way these Reynolds stresses are modelled in 2-equation eddy viscosity models like the k-epsilon, k-omega is via the eddy viscosity ( Boussinesq assumption). In short, it says that Reynolds stress=some constant times Strain rate. that constant is the eddy viscosity. Let's look at modelled Reynolds stresses in 2D case: u'u'=-2 * eddyviscosity * du/dx v'v'=-2 * eddyviscosity * dv/dy u'v'=-2 * eddyviscosity * 0.5(du/dy+dv/dx) NOTE that k = 0.5(u'u'+v'v'). no u'v' involved! The two equation models "do not transport" the Reynolds stresses. You need to compute them via the relations above. If you do not want a modelled form of the Reynolds stresses, you use the RSM models. Notice also in the raw RANS (momentum), you do not have have k. where is k? K is actually coupled with the pressure term so it becomes a modified pressure term. Once you solve the transport equations, it spits k out. |
variety of turbulence models in cfx? | hamidciv | CFX | 5 | January 4, 2016 02:41 |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 14:32 |
CFX Spalart Allmaras turbulence models | aweizazuji | CFX | 9 | September 24, 2013 10:53 |
Fluent's new turbulence models, how to choose ? | Santos-Dumont | FLUENT | 9 | February 25, 2012 15:48 |
How to set phase dependent turbulence models? | J.Yang | CFX | 2 | August 29, 2002 15:39 |
