Why is the concept of pressure drop through microchannels important?
Old   April 8, 2016, 11:15
Default Why is the concept of pressure drop through microchannels important?
Hugh Jones
merclarenz is on a distinguished road
Like, i know many experiments have been conducted, but why? Like why is it important to investigate it?
Thanks
merclarenz is offline   Reply With Quote
Old   April 8, 2016, 13:17
Michael Prinkey
mprinkey will become famous soon enough
Two reasons come immediately to mind. Viscous effects scale as 1/L^2 while convection scale at 1/L, so for small confided domains, viscous effect tend to dominate...see porous media. Pressure and viscous effects end up being all that is important...well, body forces too. But inertia terms are not.
Second, depending on how "micro" the microchannels are, the continuum assumption used to build the Navier Stokes equations may break down. If the scale of the channel is near the mean free path, the ballistic nature of the flow molecules will become important, so you may need a statistical mechanical description of the flow.
mprinkey is offline   Reply With Quote
Old   April 8, 2016, 13:58
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
I can immagine that the pressure drop is the main parameter for the correct transport of droplets/bubbles in microfluidic channels
FMDenaro is offline   Reply With Quote
Old   April 9, 2016, 19:26
Hugh Jones
so why would it be better to have a smaller pressure drop?
Old   April 9, 2016, 21:27
Michael Prinkey
Lower pumping losses implying higher energy efficiency. Less physical stress on the microchannel structures.
Old   April 13, 2016, 07:13
Hugh Jones
So its better to have lower pressure drops in micrrotubes?
Periodic flow using Cyclic - comparison with Fluent nusivares OpenFOAM Running, Solving & CFD 30 December 12, 2017 05:35
Orifice-Pipe Problem CFXMUFFIN CFX 3 July 16, 2015 18:57
Repeated elements in a system – pressure drop llidito OpenFOAM 0 April 25, 2013 14:47
Pressure drop? Munni FLUENT 4 March 25, 2010 14:21
a problem in calculating pressure drop in Fluent? yu chun FLUENT 1 May 18, 2004 03:40
