impinging jet data
Old   January 16, 2000, 13:22
Default impinging jet data
Andreas Abdon
Hello everybody out there!
I'm searching for high quality experimental data on impinging heat transfer, preferably with flow measurements as well for CFD validation. Key issues are inlet boundary conditions and geometry: The jet should be confined (by a wall) and channel height(H) through jet width (D) should be about 2 to 8. Axisymmetric jets as well as slot jets will do. Jet Re nr should be between 10000 and 30000. My experience is that jet exit conditions seriously affects calculated heat transfer (especially the turb. lenght scale). Therefore I'm looking for fully developed flow conditions in the jet exit.
Regards
Andreas
ps. If you need a few hints on other exp. setups maybe I can help, I have lots of stuff.
Andreas Abdon Division Heat Transfer Lund Institute of Technology Sweden
Old   January 17, 2000, 05:19
Default Re: impinging jet data
Anders Jönson
Hi Andreas,
Take a look on the experiments made by Cooper et al. They can be found throug the Ercoftac database, URL: http://vortex.mech.surrey.ac.uk/data...25/test25.html
This case has also served as a testcase for CFD, there is a paper about different turbulence models applied in this case. One of the authors is Tim Craft, at UMIST.
Regards Ander
Old   January 17, 2000, 07:52
Andreas Abdon
Hello Anders,
thanks for answering. I'd like to point out that I'm looking for a confined jet exp. setup. This is not included in the Ercoftac base yet. But still, it's an excellent site!
Regards
Andreas
Old   January 18, 2000, 21:22
Mahesh Prakash
Hi Andreas,
Check out the following paper:
"Numerical study of turbulent heat transfer in confined and unconfined impinging jets", by Behnia et al. , Vol. 20, pp 1-9, 1999.
Cheers
Old   January 19, 2000, 07:40
Jason
Hi, Mahesh Prakash, Thanks for your message, but would you please give the Journal name?
Confined Impinging Jet Geometry furley2372 Main CFD Forum 0 May 31, 2011 20:18
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 17:27
impinging jet natesan Main CFD Forum 3 March 17, 2005 05:42
impinging jet natesan Siemens 1 February 25, 2005 03:16
IMPINGING JET ........... HELP!!!!!!!! Amir Omoumi Main CFD Forum 10 August 30, 1999 22:11
