CFL condition for 2D Compressible Euler equations
Like Tree2Likes
  • 2 Post By FMDenaro
Old   August 12, 2016, 00:02
Default CFL condition for 2D Compressible Euler equations
Selig
selig5576 is on a distinguished road
Hi everyone,
I am currently coding a 2D solver for the compressible Euler equations. Prior to this I coded a 1D solver and it works like a charm, however I am running into issues for the 2D version. In terms of my method I am using the Local Lax Friedrichs method, or "Rusanov method." After a couple days of trying to figure out the problem I believe it has to do with the way I'm calculating my CFL condition.
For my 1D problem I calculate the CFL condition for my time step size or "dt" as follows:
\Delta t = \frac{CFL \Delta x}{\max{\left(\left|u\right|+c\right)}}
For the 2D problem (according to E.F. Toro) you would calculate dt as follows:
\Delta t = \frac{CFL \Delta x}{\max{\left(\left|u\right|+c,\left|v\right|+c\right)}}
When I run my code it only plots the initial condition (t = 0). In terms of my time update, it works as I am using the 'same' procedure as for the 1D case. I have included the code below. If someone could assist that would be greatly appreciated.
nx = 101;
dx = 1/(nx-1);
ny = 101;
dy = 1/(ny-1);
r = zeros(nx,ny);
u = zeros(nx,ny);
v = zeros(nx,ny);
E = zeros(nx,ny);
p = zeros(nx,ny);
x = zeros(nx,ny);
y = zeros(nx,ny);
Q = zeros(nx,ny,4);
Qnew = zeros(nx,ny,4);
F = zeros(nx,ny,4);
G = zeros(nx,ny,4);
Fh = zeros(nx-1,ny,4);
Gh = zeros(nx,ny-1,4);
gamma = 1.4;
c = zeros(nx,ny);
ah1 = zeros(nx,ny);
ah2 = zeros(nx,ny);
CFL = 0.5;
tMax = 0.25;
for j=1:ny
    for i=1:nx
        x(i,j) = (i-1)*dx;
        y(i,j) = (j-1)*dy;
    end
end
for j=1:ny
    for i=1:nx
        if (x(i,j) >= 0.5 && y(i,j) >= 0.5)
            p(i,j) = 0.4;
            r(i,j) = 0.5313;
            u(i,j) = 0.0;
            v(i,j) = 0.0;
        elseif (x(i,j) < 0.5 && y(i,j) >= 0.5)
             p(i,j) = 1.0;
            r(i,j) = 1.0;
            u(i,j) = 0.7276;
            v(i,j) = 0.0;
        elseif (x(i,j) < 0.5 && y(i,j) < 0.5)
            p(i,j) = 1.0;
            r(i,j) = 0.8;
            u(i,j) = 0.0;
            v(i,j) = 0.0;
        elseif (x(i,j) >= 0.5 && y(i,j) < 0.5)
            p(i,j) = 1.0;
            r(i,j) = 1.0;
            u(i,j) = 0.0;
            v(i,j) = 0.7276;
        end
        c(i,j) = sqrt((gamma*p(i,j))/r(i,j));
    end
end
Eig1 = abs(u) + c;
Eig2 = abs(v) + c;
dt = CFL*dx./max(Eig1(:),Eig2(:));
nt = floor(tMax/dt);
for k=1:nt
    for j=1:ny
        for i=1:nx
            E(i,j) = p(i,j)./(gamma-1) + (0.5*r(i,j))*(u(i,j).^2 + v(i,j).^2);
            Q(i,j,1) = r(i,j);
            Q(i,j,2) = r(i,j).*u(i,j);
            Q(i,j,3) = r(i,j).*v(i,j);
            Q(i,j,4) = E(i,j);
            F(i,j,1) = r(i,j).*u(i,j);
            F(i,j,2) = r(i,j).*u(i,j).^2 + p(i,j);
            F(i,j,3) = r(i,j).*u(i,j).*v(i,j);
            F(i,j,4) = u(i,j).*(E(i,j) + p(i,j));
            G(i,j,1) = r(i,j).*v(i,j);
            G(i,j,2) = r(i,j).*v(i,j).*u(i,j);
            G(i,j,3) = r(i,j).*v(i,j).^2 + p(i,j);
            G(i,j,4) = v(i,j).*(E(i,j) + p(i,j));
        end
    end
    for j=1:ny-1
        for i=1:nx-1
            ah1(i,j) = max(abs(u(i,j)) + c(i,j), abs(u(i+1,j)) + c(i+1,j));
            ah2(i,j) = max(abs(v(i,j)) + c(i,j), abs(v(i,j+1)) + c(i,j+1));
            Fh(i,j,:) = 0.5*(F(i+1,j,:) + F(i,j,:) - ah1(i,j).*(Q(i+1,j,:) - Q(i,j,:)));
            Gh(i,j,:) = 0.5*(G(i,j,:) + G(i,j+1,:) - ah2(i,j).*(Q(i,j+1,:) - Q(i,j,:)));
        end
    end
    Qnew(:,1,:)  = Qnew(:,2,:);
    Qnew(1,:,:)  = Qnew(2,:,:);
    Qnew(:,ny,:) = Qnew(:,ny-1,:);
    Qnew(nx,:,:) = Qnew(nx-1,:,:);
    for j=2:ny-1
        for i=2:nx-1
            Qnew(i,j,:) = Q(i,j,:) - (dt/dx)*(Fh(i,j,:) - Fh(i-1,j,:)) - (dt/dy)*(Gh(i,j,:) - Gh(i,j-1,:));
        end
    end
    Q = Qnew;
    r = Qnew(:,:,1);
    u = Qnew(:,:,2)./Qnew(:,:,1);
    v = Qnew(:,:,3)./Qnew(:,:,1);
    E = Qnew(:,:,4);
    p = (gamma-1)*(E - (0.5*Qnew(:,:,1))*(u.^2 + v.^2));
end
figure(1)
contour(x,y,r);
xlabel('x');
ylabel('y');
title('Density');
selig5576 is offline   Reply With Quote
Old   August 12, 2016, 04:14
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
My idea is that the definition of the CFL in multidimensional cases is more complex. I give you a very simple example. If in the 1D scalar equation df+udf/dt=0 we introduce the cfl =u*dt/dx, it is quite straightforward considering that in the 2D counterpart df+udf/dt+vdf/dy=0 we have also the v*dt/dy component of the cfl.
Now the real issue is in how they affect the numerical stability. But for giving an answer you should always consider the numerical method. For example, if you use a forward time and first order upwind then you get into the condition:
u*dt/dx + v*dt/dy<=1
If you use different methods you can get different stability conditions.
In the case of non-linear equations the problem is much more difficult, the linear stability analysis gives some approximate indications but you have to consider that u and v are local (as well as the sound velocity).
In general, I suggest to compute dt from the worst conditions you can consider in you flow problem.
juliom and aerosayan like this.
FMDenaro is offline   Reply With Quote
Old   August 12, 2016, 19:11
Default Cfl
Selig
Hi FM Denaro,
I agree with your suggestion. With that being said from literature it seems that you calculate your time step from the system's largest eigenvalue. As such I have tried implementing that along with playing around with numbers, but have reached no luck. In fact, I am getting "NaNs" in my arrays, which I know is from the CFL condition not being satisfied (that I know of).
Would maybe trying RK3 or RK4 help with the time step restrictions?
Old   August 13, 2016, 03:37
Originally Posted by selig5576 View Post
Hi FM Denaro,
First, I suggest to try entering into the stability region by diminuishing progressively the time step. If that does not work it is likely you have a bug in the code.
Old   August 18, 2016, 07:18
Anisette is on a distinguished road
Higher CFL number means higher time step limit.But to be able to use a larger CFL number,method should be more stable which means number of step should be higher. NAN solution comes probably because of using time in the unstable region. Try to increase number of step, i.e. use RK4 instead RK2. In addition, use lower CFL number. About the calculation of time step from CFL number, it will not be that easy for 2D case. I can recommend you to look at Computational Gasdynamics, Culbert B. Laney or Computational Fluid Dynamics for Engineers, Klaus Hoffmann and Steve T.Chiang
Anisette is offline   Reply With Quote
Old   August 18, 2016, 10:08
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
You may want to consult Blazek, Computational Fluid Dynamics, 3rd ed., paragraph 6.1.4 (pp. 173) for an account of possible methods to determine the stability time step. For cell centered finite volume on unstructured grids i currently use:
dt_c = CFL * V_c / SUM_f_c[(conv_f+visc_f)*A_f]
where V_c is the volume of cell c, the SUM_f_c is over the faces f of cell c, A_f is the face area and conv/visc_f are the maximum (in value) eigenvalues of the convective and viscous contributions. In your case the viscous one is null but, for the convective one, i would use:
conv_f = ABS(u_j n_j) + c
where n_j is the j-th component of the face normal and u_j is the j-th component of the face velocity. Maximum allowable CFL is obviously scheme dependent.
sbaffini is offline   Reply With Quote
Old   August 19, 2016, 16:40
Default Got it to work
Selig
Hi everyone,
I greatly appreciate all the helpful replies, however I was able to detect the issue in the code. I needed to have (r0, u0, v0, E0) and use that to get (r, u, v, E). In fact, my CFL condition I had is currently working good. That being said I have a side question: Since I am using the TVD Lax Friedrichs (aka Rusanov aka Local Lax Friedrichs) would implementing the TVD Runge Kutat (3rd order) make a significant improvment in terms of the accuracy? I am currently writing a hydrodynamics code for computing fluid instabilities, such as Rayleigh-Taylor instability and Kelvin Helmholtz instability.
Old   August 19, 2016, 16:45
Hi everyone,
Well, you can get an improving in the temporal accuracy but the leading term of the local truncation error will be always constrained by the spatial discretization of the L-F method.
Old   May 17, 2018, 04:59
Default 2D Compressible Euler equations
Animesh Bhowmik
animesh85 is on a distinguished road
Hi everyone,
nx = 101;
dx = 1/(nx-1);
ny = 101;
dy = 1/(ny-1);
r = zeros(nx,ny);
u = zeros(nx,ny);
v = zeros(nx,ny);
E = zeros(nx,ny);
p = zeros(nx,ny);
x = zeros(nx,ny);
y = zeros(nx,ny);
Q = zeros(nx,ny,4);
F = zeros(nx,ny,4);
G = zeros(nx,ny,4);
gamma = 1.4;
c = zeros(nx,ny);
ah1 = zeros(nx,ny);
ah2 = zeros(nx,ny);
CFL = 0.5;
tMax = 0.25;
for j=1:ny
    for i=1:nx
        x(i,j) = (i-1)*dx;
        y(i,j) = (j-1)*dy;
    end
end
for j=1:ny
    for i=1:nx
            p(i,j) = 0.4;
            r(i,j) = 0.5313;
            u(i,j) = 0.0;
            v(i,j) = 0.0;
             p(i,j) = 1.0;
            r(i,j) = 1.0;
            u(i,j) = 0.7276;
            v(i,j) = 0.0;
            p(i,j) = 1.0;
            r(i,j) = 0.8;
            u(i,j) = 0.0;
            v(i,j) = 0.0;
            p(i,j) = 1.0;
            r(i,j) = 1.0;
            u(i,j) = 0.0;
            v(i,j) = 0.7276;
        end
    end
end
Eig1 = abs(u) + c;
Eig2 = abs(v) + c;
for k=1:nt
    for j=1:ny
        for i=1:nx
            Q(i,j,1) = r(i,j);
            Q(i,j,4) = E(i,j);
        end
    end
    for j=1:ny-1
        for i=1:nx-1
        end
    end
    for j=2:ny-1
        for i=2:nx-1
        end
    end
    Q = Qnew;
    r = Qnew(:,:,1);
    E = Qnew(:,:,4);
end
figure(1)
contour(x,y,r);
xlabel('x');
ylabel('y');
title('Density');
Can u provide the link of the reference paper/journal in which the detailed discussion on 2D Local Lax Fedrich method is explained
animesh85 is offline   Reply With Quote
Old   May 17, 2018, 06:48
Default 2d llf
Selig
Instead of a 1D integral of the flux you are dealing with a 2D surface integral. Since for a 2D conservation law you have 2 fluxes, say F and G (assuming you have no source terms) you need to apply the flux discretization to both at the faces of your control volume. A good reference is the book by Toro or Leveque. If you are an engineer you may appreciate the book by Toro more. Mind you, this was my first 2D code as I was just starting to learn CFD, so I think there are errors.
Old   May 18, 2018, 10:23
Truong Dang
ssh123 is on a distinguished road
@selig5576 I suggest updating your DT at each time integration step.
ssh123 is offline   Reply With Quote
Suitable inlet boundary condition for a compressible flow simulation siw FLUENT 13 October 9, 2018 23:54
Smallest element, simpleFoam and CFL condition jbernardo OpenFOAM 10 September 27, 2017 11:50
outlet boundary condition for compressible flow with no definite details chem engineer FLUENT 2 July 12, 2015 19:51
Analytic solution for 2D steady Euler equations jojo81 Main CFD Forum 0 October 15, 2012 12:05
Euler equations? Jan Ramboer Main CFD Forum 2 August 19, 1999 01:58
