Limitations on time the step for lid driven cavity flow |
October 21, 2016, 10:48 |
Juan Camilo Acosta Arango
Rep Power: 10 |
I'm following these slides
http://www3.nd.edu/~gtryggva/CFD-Cou...-Lecture-5.pdf They formulate N-S equations usin stream, vorticity functions, I'm want to know what kind of analysis they do to conclude the time step restriction showed in the page 5. Its very important for me to know how it is done, thanks!
Juan Camilo Acosta Arango |
October 21, 2016, 10:58 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
It stems from the numerical stability analysis for the explicit Forward Time Central Space (FTCS) applied on a 2D convection-diffusion equation. Note that the first constraint is exact only for the pure diffusive case (no convection). The method is unconditionally unstable for the pure convective case. In the mixed case the constraint involves a more complex functional law in the (cfl, Reh) plane. You can find details in any good CFD textbook. |
October 21, 2016, 11:11 |
#3 | |
Rep Power: 10 |
October 21, 2016, 11:17 |
Rep Power: 71 |
Yes. The Von Neumann analysis is applied for the linear case (as well as the matrix analysis you can perform by using the Gershgorin locus method). The constraint in those slides are valid for the linear equation. Usually, they are roughly used also for the non linear equation.
October 21, 2016, 11:18 |
Rep Power: 71 |
P.S.:the second constraint must have the ratio to the mesh size h but, as I wrote, the case for the pure convective case is unstable. The key for a wiggles-free solution is to work with the Reh<2 condition.
October 21, 2016, 11:20 |
Rep Power: 10 |
sorry to be annoying, but do you know any paper or article where this specific analysis is done?
October 21, 2016, 11:26 |
Fletcher: Computational Techniques for Fluid Dynamics, Vol. 2, pp. 335 cites a more general condition for the 2D equations. He actually cites this:
http://link.springer.com/book/10.100...-3-642-85952-6 pp. 183 as original source. If you don't trust them, I swear, I did it by myself (straightforward Neumann on the equivalent scalar equation) and it is correct . It is (): Last edited by sbaffini; October 21, 2016 at 11:45. Reason: Added the actual formula from Fletcher |
October 21, 2016, 11:57 |
#8 | |
Rep Power: 10 |
October 21, 2016, 12:05 |
Rep Power: 71 |
you can read any good textbook of both CFD and numerical anlysis...
as example, http://dl.iranidata.com/book/daneshg...idata.com).pdf |
October 21, 2016, 12:32 |
#10 | |
Rep Power: 10 |
You mentioned something about "straightforward Neumann on the equivalent scalar equation", may you point me to some source about these formulation and the analysis done over it?
October 21, 2016, 12:55 |
#11 |
That's what i meant by all those "cites" and "swear". If you can handle the italian language between the 14 equations on 2 pages (i guess so), here it is attached my old analysis. As you can see, it is pretty straightforward Neumann analysis.
October 21, 2016, 18:28 |
#12 |
Rep Power: 71 |
I strongly suggest to plot the amplification factor for the value = 1 in the (Reh, cfl) plane.
October 21, 2016, 19:13 |
#13 |
Rep Power: 71 |
This issue is not as simple as it would appear...
https://estudogeral.sib.uc.pt/bitstr...20analysis.pdf Last edited by FMDenaro; October 22, 2016 at 10:19. |
time step size |
Transient simulation not converging | skabilan | OpenFOAM Running, Solving & CFD | 14 | December 16, 2019 23:12 |
Stuck in a Rut- interDyMFoam! | xoitx | OpenFOAM Running, Solving & CFD | 14 | March 25, 2016 07:09 |
time step directories naming issue | Andrea_85 | OpenFOAM | 3 | April 3, 2014 08:38 |
dynamic Mesh is faster than MRF???? | sharonyue | OpenFOAM Running, Solving & CFD | 14 | August 26, 2013 07:47 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 05:24 |
