Mesh generation for 3d airfoil woth serrations |
February 20, 2017, 16:13 |
abhi
Rep Power: 9 |
M planning to analyze 3d airfoil with trailing edge serrations.but the problem is m not much familiar with the mesh generation techniques and which mesh should i use. The simulation will be for low subsonic flows.
I actually watched some tutorials for icem cfd but i didnt get much imformation which can help me. So, Can anyone tell me how should i approch this problem in order to get valid result.like what kind of mesh is required.? Thanku IMG-20170219-WA0013.jpegIMG-20170219-WA0012.jpegIMG-20170219-WA0005.jpeg Sent from my ONEPLUS A3003 using CFD Online Forum mobile app |
February 20, 2017, 17:55 |
Michael Prinkey
Rep Power: 25 |
I am no meshing expert, but I can tell you that you've picked a challenging problem. I would mesh the top of the fluid serrations first (with triangles) and extrude them into wedges. That would fill all of the serrated flow volume. Then mesh the serrated solid surface also with triangles. Then try to mesh the normal surface of the wing with quads if possible. Then extrude all of those surfaces out to fill your flow domain with mixed hex/wedges. You should be able to control your mesh density well in the serrated flow area using triangles. Extruding those should give you good control of the boundary layer spacing. The same will be try extruding into the main flow area around the wing.
Good luck. |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
[ICEM] 2d Undtructured mesh around airfoil with boundary mesh | samiyare | ANSYS Meshing & Geometry | 2 | September 21, 2013 00:29 |
Problem with restart solution in shape_optimization.py | robyTKD | SU2 Shape Design | 21 | May 29, 2013 09:26 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
