Creating UDF with changing velocity with time
Old   March 8, 2017, 11:34
Unhappy Creating UDF with changing velocity with time
jabeztan is on a distinguished road
I was asked to write the UDF for a 2D room and it has to change velocity in terms of time. Like, when the time is 0 to 2 seconds, the velocity magnitude is horizontal. Then 2 to 4 seconds, the velocity changes magnitude and so on until the velocity is vertical. For example, the velocity is flowing into the inlet at 0 degree then changes with time to 90 degrees. After that, it flows down to 0 degree then repeat. It is like moving fan blowing into the inlet from 0 degree to 90 degrees.
Please help with this because I have no knowledge on writing UDF at all.
Thanks!
jabeztan is offline   Reply With Quote
#ansys, #fluent, #time, #udf, #velocity
AMI speed performance danny123 OpenFOAM 21 October 24, 2020 04:13
Time dependent angular velocity calculation UDF shashankmechguy Fluent UDF and Scheme Programming 1 July 26, 2018 02:23
UDF for time dependent angular velocity calculation shashankmechguy Fluent UDF and Scheme Programming 2 October 24, 2016 04:43
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 02:50
