August 18, 2017, 06:32 |
Pressure Wave Speed
Patrick Boyle
Rep Power: 8 |
I am attempting to model pressure waves and resonance within a cavity with flow.
There is an unsteady heat source oscillating at 3.7kHz producing pressure waves. When I run to completion, I observe resonance which tallies with experiment. Through the use of monitor points I can see the initialising pressure wave as it travels down the length of the cavity and by measuring the difference between arrival times I calculate the average wave speed between monitor points. What is odd is that the wave speed 384m/s is well in excess of the local acoustic speed which is a constant 346m/s between the monitor points. Even allowing for the local flow velocity(~14m/s), this wave would appear to be travelling at supersonic speeds. Is this an inaccuracy of the CFD simulation and if so what can I do to correct this? |
August 18, 2017, 09:25 |
Filippo Maria Denaro
Rep Power: 71 |
I am not sure to understand your problem...
the sound wave velocity depends on the temperature field, being a=sqr(gamma*R*T), therefore I am not surprised that a heat source can increase the velocity propagation... Maybe you should give the full details of the simulation |
August 18, 2017, 09:38 |
Patrick Boyle
Rep Power: 8 |
The temperature around the source does increase, however over the region that I am examining the temperature is a constant 25C, so the acoustic speed is fixed. There has not been enough time for the heat to propagate.
August 18, 2017, 09:52 |
Patrick Boyle
Rep Power: 8 |
The cavity in question, with monitor points marked in yellow, looks something like this
transient_LES_3_7kHz_HighRes.jpg whilst the acoustic speed for the cavity looks like this acoustic_speed.png |
August 18, 2017, 09:53 |
Rep Power: 71 |
Well, so assume you have 298 K of temperature, consider R and gamma for your fluid (I don't know if you have air) and compute the sound velocity a.
Then, the propagation follows the eigenvalues (for simplicity I am considering an inviscid flow) of the Euler equation |u|+a and |u|-a. Try to make an estimation for the local advection velocity and check if the result is acceptable. |
Periodic flow using Cyclic - comparison with Fluent | nusivares | OpenFOAM Running, Solving & CFD | 30 | December 12, 2017 05:35 |
interFoam (HELYX-OS) pressure boundary conditions | SFr | OpenFOAM Running, Solving & CFD | 8 | June 23, 2016 16:36 |
Pressure BC for combustion chamber | Giuki | FLUENT | 1 | July 19, 2011 11:35 |
How to find the reflections of the pressure wave in pipe lines | RKR | Main CFD Forum | 0 | April 6, 2011 08:08 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 02:15 |
