[Scripting]: How to get the coordinates of a 2D airfoil @ different angles of attack?
Like Tree2Likes
  • 2 Post By Flowkersma
Old   November 25, 2017, 00:37
Default [Scripting]: How to get the coordinates of a 2D airfoil @ different angles of attack?
CfdIntro is on a distinguished road
I have this piece of code which calculates the coordinates of a point(qx,qy) after it is rotated around an origin(ox, oy) by an angle(angle):
import math
def rotate(origin, point, angle):
ox, oy = origin
px, py = point
qx = ox + math.cos(angle) * (px - ox) - math.sin(angle) * (py - oy)
qy = oy + math.sin(angle) * (px - ox) + math.cos(angle) * (py - oy)
return qx, qy
print(rotate((ox, oy), (px, py), math.radians(angle)))
I want to get the coordinates of an airfoil at different angle of attacks. For this, I want the final script to be able to read the x,y coordinates of the airfoil at 0 degrees angle of attack from a .txt file, do the calculation for all the coordinates for a new angle of attack and then export the results to a new .geo file.
I have this code that lets the script to open the .txt file with the coordinates at 0 angle of attack:
coordsAt0 = []
with open('coordinatesAt0.txt') as fin:
fin.readline()
for l in fin:
coords = map(float,l.split())
coordsAt0.append(coords[:2])
After the calculation of the coordinates for the new angle of attack, I have this code which exports the new coordinates to a new .geo file.
with open('newcoordinates.geo','w') as fout:
for i, c in enumerate(coordsAt0):
fout.write('Point (%i) = {%f, %f, 0, 1};\n'%(i+1,c[0],c[1]))
My problem is how should I implement the code that calculates the new coordinates of the airfoil at a new angle of attack?
Any hint or a simpler piece of code on how to do it would be greatly appreciated!
Regards,
CfdIntro
CfdIntro is offline   Reply With Quote
Old   November 26, 2017, 14:43
Mikko
Flowkersma is on a distinguished road
Looks like a familiar piece of code :-)
After line
You can just add the rotate function call
angle = 10 # degrees
origin = (0,0)
coords0 = rotate(coords[:2], origin, math.radians(angle))
coordsAt0.append(coords0)
Regards, Mikko
lcarasik and CfdIntro like this.
Flowkersma is offline   Reply With Quote
Old   December 12, 2017, 10:23
Originally Posted by Flowkersma View Post
After line
origin = (0,0)
Regards, Mikko
I was trying to have the script open the .txt file with the coordinates at 0 AoA, rotate the coordinates by the desired AoA, print the results into a new .txt file, then read the coordinates at the new AoA and finally export the results into a .geo format file. That being said, your suggestion saved me about 30 lines of code!
Thanks again for the tip
Regards,
CfdIntro
airfoil 2d, angle of attack, coordinates from .txt, python script
Ffd_control_point_2d feiyi SU2 4 September 30, 2019 12:42
High drag for airfoil compared to XFOIL and wind tunnel data Ry10 SU2 15 October 30, 2016 17:27
2D FFD Optimization RLangtry SU2 2 August 5, 2014 09:48
Automatic Simulation of 2D Airfoil Section at Different Angles of Attack Hybrid ANSYS 3 May 10, 2012 22:26
Airfoil simulation in High Angles of Attack Yasser Nabavi FLUENT 0 April 21, 2006 17:28
