Object moving in a channel or tube with stationery air |
January 4, 2018, 20:03 |
Rep Power: 8 |
hi, i'm cfd newbie. May i know why is it most cases using car as stationery object and air as moving object instead of car moving in stationery air as real case?
If i want to observe how the airflow and pressure flow behave over time when the car travel from start to end of tunnel. Is it acceptable if i set the car wall as moving wall, start of tunnel as inlet velocity, end of tunnel as outlet pressure, other regions of air in tunnel as zero gradient, and tunnel wall as stationery no slip wall? Sorry for my silly question but I really need help in this matter. Thanks for help =) |
January 5, 2018, 03:57 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
In the case of simulation of a car in a tunnel you could consider the car fixed and the walls of the tunnel moving. However, if you are able to simulate the complete movement of the geometry of the car over a computational grid in the tunnel that would be ok. |
January 8, 2018, 20:13 |
reply
#3 | |
Rep Power: 8 |
internal field, U= uniform ( 0 20 0), P= uniform 0, inlet, U= uniform ( 0 20 0), P=zeroGradient outlet, U = zeroGradient, P= totalPressure P0=0 tunnelWall, U=movingWallVelocity uniform (0 0 0), P=zeroGradient carWall, U= noSlip, P=zeroGradient and zeroGradient for all other turbulent fields (eg: nut, k, epsilon) HTML Code:
Courant Number mean: 0.335262 max: 2.83168 smoothSolver: Solving for Ux, Initial residual = 0.694223, Final residual = 9.76037e-06, No Iterations 102 smoothSolver: Solving for Uy, Initial residual = 0.74074, Final residual = 9.45336e-06, No Iterations 107 smoothSolver: Solving for Uz, Initial residual = 0.814794, Final residual = 9.14118e-06, No Iterations 111 GAMG: Solving for p, Initial residual = 0.735763, Final residual = 0.0681959, No Iterations 10 time step continuity errors : sum local = 0.0811912, global = -0.0341982, cumulative = -0.0266287 GAMG: Solving for p, Initial residual = 0.234852, Final residual = 9.16891e-07, No Iterations 115 time step continuity errors : sum local = 2.3507e-06, global = 6.11098e-07, cumulative = -0.026628 |
engineFoam with layers - pressure problems when adding layers | mturcios777 | OpenFOAM Running, Solving & CFD | 23 | January 4, 2023 21:56 |
What kind of mesh to use for cylindrical object in channel | nihossain | FLUENT | 1 | November 2, 2011 01:16 |
UDF of tube moving with pendulum motion | Esther | FLUENT | 0 | July 7, 2008 04:33 |
How to model Object to cool in an Air Stream | JW | FLUENT | 1 | May 11, 2006 02:11 |
moving water from a chamber using air | Matt Mason | CFX | 0 | December 2, 2003 19:46 |
