Question for candidates for CFD analysts
Old   January 10, 2018, 14:01
Default Question for candidates for CFD analysts
Tscar is on a distinguished road
I was wondering what kinds of guestion regarding CFD would you ask an candidate for job in CFD?
I other words, what do you think are the basic knowledge CFD practitioners should know and when is it ok to just know where to look?
The hypothetical person you would be guestioning is a regular CFD analyst with say 3 years of pactice, mostly in comercial code...
Thank you for your answers and I hope for interesing discussion below.
T.
Tscar is offline   Reply With Quote
Old   January 11, 2018, 10:38
Default CFD job questions
Selig
selig5576 is on a distinguished road
It depends on the type of CFD job. If your going into development they are going to ask you more theory questions. If your going into practice (using Fluent, OpenFoam) they might ask you questions more tailored to the software.
If you applied for a developer position they could ask you about turbulence models and numerical methods. In fact I would not be surprised if they asked you like "whats the difference between uniform and nonuniform flow."
selig5576 is offline   Reply With Quote
Old   January 11, 2018, 13:04
Matt
fluid23 is on a distinguished road
What is the difference between a RANS/URANS analysis and DNS?
What is the difference between LES and DES?
What is a Newtonian fluid?
How do you select (or down select) turbulence models?
What is a wall model and how does it factor into a solution?
What are some of the limitations you see with CFD?
What are some of it's advantages?
How you would ensure your results are not mesh dependent?
fluid23 is offline   Reply With Quote
Question about symmetry in Autodesk Cfd 2016 ecto Autodesk Simulation CFD 0 October 20, 2015 04:16
small question about the functionalities of topological changes in OpenFoam ngj OpenFOAM Running, Solving & CFD 2 February 28, 2013 10:02
Question Re Engineering Data Source imnull ANSYS 0 March 5, 2012 13:51
internal field question - PitzDaily Case atareen64 OpenFOAM Running, Solving & CFD 2 January 26, 2011 15:26
CHANNEL FLOW: a question and a request Carlos Main CFD Forum 4 August 23, 2002 05:55
