Calculation of pressure drag with pressure coefficient distribution |
February 5, 2018, 17:26 |
Xilef Smith
Rep Power: 9 |
Dear,
I am trying to calculate the pressure drag with an obtained pressure coefficient distribution according to: Cd_p(i) = Cp(i) * dy(i) I have a geometry described by x and y coordinates, and dy is the difference in y direction between each point. I therefore first calculate Cp*dy and calculate the area under the curve, which should be equal to the integral of Cp*dy. (Attached is the graph of the curve) However, when I increase the number of points describing my geometry, automatically dy will be smaller as the distance between two points becomes smaller. Therefore, the whole Cp*dy curve shifts downwards leaving me with a smaller value of integral, hence smaller value of Cd which should not be the case. I know I'm going wrong somewhere but can't seem to figure out where. Any help or advise is appreciated! Cheers! Last edited by Springroove; February 6, 2018 at 05:43. |
February 6, 2018, 00:35 |
Uwe Pilz
Rep Power: 15 |
I don't understand fully hat you try to calculate. But you have to use the same area (or line, in 2D) for calculation of the pressure. For a flow past a body you may use the whole surface. It doesn't count then how small the elements are.
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
February 6, 2018, 05:42 |
Xilef Smith
Rep Power: 9 |
Thank you for your answer. I am trying to calculate the drag coefficient which is would be Cp*dy. But my area under the curve always changes with different dy, because I have Cp*dy on my y axis.
If I understand correctly, the drag coefficient is the integral of Cp*dy from the front to the back right |
February 6, 2018, 06:25 |
#4 | |
Uwe Pilz
Rep Power: 15 |
Pressure drag, friction drag and total drag? | Cheng | CFX | 9 | January 26, 2024 13:46 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
Pressure coefficient distribution | reynolds_master | Main CFD Forum | 2 | January 10, 2015 15:33 |
Drag Coefficient Calculation | antonusklesk | Phoenics | 1 | August 29, 2012 05:07 |
lid-driven cavity in matlab using BiCGStab | Don456 | Main CFD Forum | 1 | January 19, 2012 15:00 |
