How to calculate the Reynolds Stress using massive velocity-position data |
May 17, 2018, 07:25 |
Matthew
Rep Power: 8 |
Hi, all. I am pretty new for this, so sorry for this stupid simple question.
Now I would like to plot the Reynolds stress (u'v’) for my jet flow on a certain cross section. I have totally 36000 groups of data that sampled from the cross section based on 100 time steps multiplied 360 radial lines, each group have the u, v, w velocity of 200 points on the radial line, i.e. totally I have a 200×36000 mat in MATLAB. So my question is that how can I get the figure of Reynolds stress versus radial locations (u'v' versus r/D), as well as the turbulence intensity (u'u', v'v', w'w' versus r/D). Really thanks for any suggestion. |
May 17, 2018, 07:38 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
First, you should compute the fluctuations. If you have data sampled along a sufficient time interval, you can first compute the time-averaged fields. Then use this field to compute the fluctuations at each time you have the sample. This way, you get the vector field v'(x,t) and then you can compute the Reynolds tensor. Usually, supplementary spatial averaging are used (for example in azimuthal direction) along with the time averaging. |
May 17, 2018, 18:05 |
Lucky
Rep Power: 66 |
You have u(x,y,z,t) v(x,y,z,t) and w(x,y,z,t) where (x,y,z) are coordinates or u(x,t), v(x,t), w(x,t) if you consider x the position vector.
Ok so for every x,y,z / x you average in time to get the mean velocities at each location. So you should have 360*200x3 average velocities. Since you have a 200x3600 matrix in matlab, you can probably accomplish this using Code:
uMean = mean(u,1) Code:
uPrime = u - uMean(ones(200,1),:); Code:
uu = mean(uPrime.*uPrime,1); uv = mean(uPrime.*vPrime,1); It really is as simple as these few lines of code. And then happy plotting. |
May 17, 2018, 23:18 |
#4 | ||
Matthew
Rep Power: 8 |
1. The correct plots of u'u'_vs_x/D and u'v'_vs_x/D, and my plot are attached. It seems that my results are far away from the correct one. First issue is the y axis value, my value is normalized by Uc, the centre line axial velocity of the cross section of the jet. Is that correct? 2. For the plot of u'v'_vs_x/D, is the u'v' come from simply uPrime multiplying by vPrime? If so, how can the y axis value u'v'=0 at x=0, because both my uPrime and vPrime at x=0 are not 0. Thanks again for your patient reply. |
May 18, 2018, 00:08 |
Lucky
Rep Power: 66 |
2. You still have to take the average in time.
May 18, 2018, 00:43 |
Matthew
Rep Power: 8 |
Actually I have average the data both on time (100 timesteps) and space (360 radial lines). So is that means the time is not long enough for the data? Now the 100 time steps are extracted from 0.5 second for the flowing.
Cheers. |
May 18, 2018, 02:43 |
#7 | |
Rep Power: 71 |
The time-averaging must be performed over a large interval. Considering the non-dimensional time unit using a characteristic integral time scale. you need to average over 20-30 time units. I suggest to plot the time averaged velocity profiles |
February 10, 2020, 04:18 |
ike
Rep Power: 6 |
Hello, I am realitively new to matlab and couldnt figure out a script for my Reynolds Normal stresses. Can you please help me write the whole script.
February 10, 2020, 04:20 |
ike
Rep Power: 6 |
We are only given velocities in the x and y direction.
February 10, 2020, 13:23 |
#10 | |
Lucky
Rep Power: 66 |
Did you check out post #3? You only need to add two lines, one for vMean and vPrime and maybe change the 1 to either a 2 (or 3) depending on what format your data actually is in. |
[OpenFOAM] How to get the coordinates of velocity data at all cells and at all times | vidyadhar | ParaView | 9 | May 20, 2020 20:06 |
"Error in subroutine GETCORE": simulation of an turbine and reynolds stress models | nikn | CFX | 8 | October 30, 2019 15:32 |
Run OpenFoam in 2 nodes of a cluster | WhiteW | OpenFOAM Running, Solving & CFD | 16 | December 20, 2016 00:51 |
Help with UDF to calculate the bubble velocity for 2 phase gas | enass massoud | Fluent UDF and Scheme Programming | 0 | October 18, 2016 06:11 |
Combustion Convergence problems | Art Stretton | Phoenics | 5 | April 2, 2002 05:59 |
