July 13, 2018, 10:12 |
fluent programmas
mariana
Rep Power: 12 |
I would like to ask you something. In my work, we are looking to buy one fluent program in order to calculate the pressure drop. do you know, which program is better ? we are looking between ansys fluent and pipe flow. but as I will work on the program, I am wondering in which program is more friendly to the user. do you have another program in your mind? thank you very much Mariana |
July 17, 2018, 17:35 |
Lucky
Rep Power: 66 |
If you only want to know the pressure drop, probably Pipe Flow.
Fluent solves the Navier-Stokes equations, which sounds like overkill. As far as I know, Pipe Flow is a flow network solver, much more crude but can get you your answer probably much faster and maybe even more accurately. For example, if you want to calculate the pressure drops in a city network of water pipes that runs for several kilometers, pipe flow would be the way to go. It is not too difficult to write your own flow network solver using matlab/simulink or excel and vba. But both will lack a nice GUI unless you also develop it. All you need is some fluids know-how and some programming familiarity. |
CFX vs. FLUENT | turbo | CFX | 4 | April 13, 2021 08:08 |
How to solve UDF compilation problems in Fluent. | pakk | Fluent UDF and Scheme Programming | 16 | September 10, 2018 02:48 |
Two questions on Fluent UDF | Steven | Fluent UDF and Scheme Programming | 7 | March 23, 2018 03:22 |
heat transfer with RANS wall function, over a flat plate (validation with fluent) | bruce | OpenFOAM Running, Solving & CFD | 6 | January 20, 2017 06:22 |
Problems in lauching FLUENT | Lourival | FLUENT | 3 | January 16, 2008 16:48 |
