July 16, 2018, 08:37 |
tests for system ode solvers
Marco Ghiani
Rep Power: 15 |
Hi everybody !
I'm looking for a place (into the web of course) in which I can find a differential problem (system of ode or ode) in order to testing an ode solver that I wrote just for me ... the best thing is to find a series of a differential problem with or without the analytical solution please let me know ! |
July 16, 2018, 09:41 |
Marco Ghiani
Rep Power: 15 |
yes but for the system, I don't have any idea ... I would like to find some academic text (pdf) in which there is some exercise ... but i didn't found yet
July 16, 2018, 09:45 |
Let say that your dependent variables are yi and the independent ones are xi, for i from 1 to n.
Pick up a typical system and a solution yi(xi) you think is representative. Put the solution in the system and use the resulting unbalanced terms as source terms in the system. That's it |
July 16, 2018, 10:00 |
Marco Ghiani
Rep Power: 15 |
I'm sorry .. but I really didn't get the point could you explain me with an example?
July 16, 2018, 10:33 |
Let's say your equation is:
dy/dx + y = s and you want your solution to be, say, y=sin(x-1). Then, inserting your wanted solution in your equation, you get: s=sin(x-1)+cos(x-1) If you use this s and the initial condition y(0)=sin(-1), then your solution to the given problem will be y=sin(x-1). For a system of equations you can just parameterize the solution you want on the ewuation index i. |
July 16, 2018, 10:54 |
Marco Ghiani
Rep Power: 15 |
ok now I got the point !! thank you very much !
July 16, 2018, 12:14 |
Filippo Maria Denaro
Rep Power: 71 |
Many classical exercises are present in basic textbooks of numerical analysis, I suggest starting from simple test cases like the integration of linear ode, such as
dx/dt =u(x,y) dy/dt= v(x,y) for example using the velocity components of a circular motion. Then, you can add the time variability of the components. |
Solid Mechanics Solvers added to OpenFOAM Extend | bigphil | OpenFOAM Announcements from Other Sources | 26 | October 12, 2017 04:01 |
How to use the ODE solvers in OpenFoam to solve CFD problems? | mod0 | OpenFOAM Running, Solving & CFD | 0 | October 14, 2015 02:57 |
FSI solvers - best solvers | steven123 | OpenFOAM Running, Solving & CFD | 0 | July 8, 2014 10:26 |
Two ODE objects simultaneously | JBUNSW | OpenFOAM Programming & Development | 0 | November 28, 2012 21:46 |
Help linking icoFoam and ODE solvers | skabilan | OpenFOAM | 6 | January 6, 2009 05:33 |
