July 26, 2018, 04:03 |
Compiling CFL3D
William Tougeron
Rep Power: 15 |
Hi all,
It seems the CFL3D code was recently set public again after a long period. The fact is that the official way ton compile it seems a bit outdated. Even the doc says: "The Install script is very old, and may or may not create a workable makefile for your particular machine." (here) While I followed instructions, I get the following error: Code:
$ ./Install # This seems to work $ make cfl3d_mpi (...) make[1]: Entering directory `/home/tougeron/documents/installation/cfd/cfl3d/CFL3D/build/cfl/libs' mpif90 -DP3D_SINGLE -DLINUX -DINTEL -DDBLE_PRECSN -O2 -w -ip -fno-alias -xHost -traceback -module /home/tougeron/documents/installation/cfd/cfl3d/CFL3D/build/cfl/libs -r8 -c add2x.F gfortran: error: unrecognized command line option ‘-ip’ gfortran: error: unrecognized command line option ‘-fno-alias’ gfortran: error: unrecognized command line option ‘-traceback’ gfortran: error: unrecognized command line option ‘-module’ gfortran: error: unrecognized command line option ‘-r8’ make[1]: *** [add2x.o] Error 1 make[1]: Leaving directory `/home/tougeron/documents/installation/cfd/cfl3d/CFL3D/build/cfl/libs' make: *** [Zlibs] Error 2 Best regards, Last edited by taalf; July 26, 2018 at 05:08. |
July 26, 2018, 05:06 |
William Tougeron
Rep Power: 15 |
Well, I removed all occurences of the "unrecognizes command line options" in the Install script, and it started compile.
Now I have another error: Code:
============================================================== compiling cfl3d_mpi ============================================================== ( cd cfl/mpi; make -f makefile cfl3d_mpi \ FFLAG="-O2 -w /home/tougeron/documents/installation/cfd/cfl3d/CFL3D/build/cfl/libs " \ FFLAG_SPEC="-O2 -w /home/tougeron/documents/installation/cfd/cfl3d/CFL3D/build/cfl/libs " \ LFLAG="-z muldefs -fpe0" \ EXEC="cfl3d_mpi" \ CPPFLAG="-P" \ CPPOPT=" -DDIST_MPI -DDBLE_PRECSN -DP3D_SINGLE -DLINUX -DINTEL -DDBLE_PRECSN " \ AROPT="rusc" \ RANLIB="true" \ CPP="cpp" \ LLIBS="" \ FTN="mpif90" \ DIR="cfl/mpi" \ CFLSRC_D="../../../source/cfl3d/dist" \ CFLSRC_S="../../../source/cfl3d/libs" \ HEADER="../../../header" ) make[1]: Entering directory `/home/tougeron/documents/installation/cfd/cfl3d/CFL3D/build/cfl/mpi' mpif90 -DDIST_MPI -DDBLE_PRECSN -DP3D_SINGLE -DLINUX -DINTEL -DDBLE_PRECSN -O2 -w /home/tougeron/documents/installation/cfd/cfl3d/CFL3D/build/cfl/libs -c ccomplex.F gfortran: warning: /home/tougeron/documents/installation/cfd/cfl3d/CFL3D/build/cfl/libs: linker input file unused because linking not done mpif90 -DDIST_MPI -DDBLE_PRECSN -DP3D_SINGLE -DLINUX -DINTEL -DDBLE_PRECSN -O2 -w /home/tougeron/documents/installation/cfd/cfl3d/CFL3D/build/cfl/libs -c development.F gfortran: warning: /home/tougeron/documents/installation/cfd/cfl3d/CFL3D/build/cfl/libs: linker input file unused because linking not done mpif90 -DDIST_MPI -DDBLE_PRECSN -DP3D_SINGLE -DLINUX -DINTEL -DDBLE_PRECSN -O2 -w /home/tougeron/documents/installation/cfd/cfl3d/CFL3D/build/cfl/libs -c main.F gfortran: warning: /home/tougeron/documents/installation/cfd/cfl3d/CFL3D/build/cfl/libs: linker input file unused because linking not done mpif90 -DDIST_MPI -DDBLE_PRECSN -DP3D_SINGLE -DLINUX -DINTEL -DDBLE_PRECSN -O2 -w /home/tougeron/documents/installation/cfd/cfl3d/CFL3D/build/cfl/libs -c bc_blkint.F gfortran: warning: /home/tougeron/documents/installation/cfd/cfl3d/CFL3D/build/cfl/libs: linker input file unused because linking not done mpif90 -DDIST_MPI -DDBLE_PRECSN -DP3D_SINGLE -DLINUX -DINTEL -DDBLE_PRECSN -O2 -w /home/tougeron/documents/installation/cfd/cfl3d/CFL3D/build/cfl/libs -c findmin_new.F gfortran: warning: /home/tougeron/documents/installation/cfd/cfl3d/CFL3D/build/cfl/libs: linker input file unused because linking not done mpif90 -DDIST_MPI -DDBLE_PRECSN -DP3D_SINGLE -DLINUX -DINTEL -DDBLE_PRECSN -O2 -w /home/tougeron/documents/installation/cfd/cfl3d/CFL3D/build/cfl/libs -c plot3d.F gfortran: warning: /home/tougeron/documents/installation/cfd/cfl3d/CFL3D/build/cfl/libs: linker input file unused because linking not done mpif90 -DDIST_MPI -DDBLE_PRECSN -DP3D_SINGLE -DLINUX -DINTEL -DDBLE_PRECSN -O2 -w /home/tougeron/documents/installation/cfd/cfl3d/CFL3D/build/cfl/libs -c rrest.F gfortran: warning: /home/tougeron/documents/installation/cfd/cfl3d/CFL3D/build/cfl/libs: linker input file unused because linking not done mpif90 -DDIST_MPI -DDBLE_PRECSN -DP3D_SINGLE -DLINUX -DINTEL -DDBLE_PRECSN -O2 -w /home/tougeron/documents/installation/cfd/cfl3d/CFL3D/build/cfl/libs -c bc_patch.F gfortran: warning: /home/tougeron/documents/installation/cfd/cfl3d/CFL3D/build/cfl/libs: linker input file unused because linking not done mpif90 -DDIST_MPI -DDBLE_PRECSN -DP3D_SINGLE -DLINUX -DINTEL -DDBLE_PRECSN -O2 -w /home/tougeron/documents/installation/cfd/cfl3d/CFL3D/build/cfl/libs -c forceout.F gfortran: warning: /home/tougeron/documents/installation/cfd/cfl3d/CFL3D/build/cfl/libs: linker input file unused because linking not done mpif90 -DDIST_MPI -DDBLE_PRECSN -DP3D_SINGLE -DLINUX -DINTEL -DDBLE_PRECSN -O2 -w /home/tougeron/documents/installation/cfd/cfl3d/CFL3D/build/cfl/libs -c plot3t.F gfortran: warning: /home/tougeron/documents/installation/cfd/cfl3d/CFL3D/build/cfl/libs: linker input file unused because linking not done mpif90 -DDIST_MPI -DDBLE_PRECSN -DP3D_SINGLE -DLINUX -DINTEL -DDBLE_PRECSN -O2 -w /home/tougeron/documents/installation/cfd/cfl3d/CFL3D/build/cfl/libs -c rrestg.F gfortran: warning: /home/tougeron/documents/installation/cfd/cfl3d/CFL3D/build/cfl/libs: linker input file unused because linking not done mpif90 -DDIST_MPI -DDBLE_PRECSN -DP3D_SINGLE -DLINUX -DINTEL -DDBLE_PRECSN -O2 -w /home/tougeron/documents/installation/cfd/cfl3d/CFL3D/build/cfl/libs -c calyplus.F gfortran: warning: /home/tougeron/documents/installation/cfd/cfl3d/CFL3D/build/cfl/libs: linker input file unused because linking not done mpif90 -DDIST_MPI -DDBLE_PRECSN -DP3D_SINGLE -DLINUX -DINTEL -DDBLE_PRECSN -O2 -w /home/tougeron/documents/installation/cfd/cfl3d/CFL3D/build/cfl/libs -c pointers.F pointers.F:35.9: use module_kwstm, only:kws_get_nummem 1 Fatal Error: Can't open module file 'module_kwstm.mod' for reading at (1): No such file or directory make[1]: *** [pointers.o] Error 1 make[1]: Leaving directory `/home/tougeron/documents/installation/cfd/cfl3d/CFL3D/build/cfl/mpi' make: *** [Zmpi] Error 2 |
July 26, 2018, 05:33 |
William Tougeron
Rep Power: 15 |
OK, I copy-pasted the following files from build/cfl/libs/ to build/cfl/mpi/ and it continues compiling:
module_kwstm.mod module_profileout.mod module_contour.mod Let's see if it will be OK now. |
July 26, 2018, 05:45 |
I faced similar issues a while ago. Whilst I don't remember the specifics the notes I wrote for my future self are as follows:
Everything is easier with MPICH - just go sudo apt install MPICH ./Install mv ~/CFL3D/build/makefile ~/CFL3D/build/makefile.bu cp ~/CFL3D/build/makefile_mac_gnu ~/CFL3D/build/makefile now modify the makefile from gfortran to mpif90 I found I ended up having to run install more than once last time? For MPI you still need the cfl3d.inp It took me a while to work out how to open the files in Paraview. To do this open the the .g file in as a Plot3D. There is then an option to open the .q file in the properties section for the Paraview source. Good luck. |
July 26, 2018, 05:57 |
William Tougeron
Rep Power: 15 |
OK, so it seems the compilation completed well.
Here, a sum up of what I did (CFL3D v6 on Linux Mint 17.3 64bit): EDIT: the method given in previous/following comments seems to be better than this one. 1- Download the CFL3D code: Code:
git clone https://github.com/nasa/CFL3D Code:
cd CFL3D/build/ ‘-ip’ ‘-fno-alias’ ‘-traceback’ ‘-module’ ‘-r8’ '-xHost' '-fpe0' 4- Launch the 'Install' script: Code:
./Install Code:
make cfd3d_libs Code:
cp cfl/libs/*.mod cfl/seq/ cp cfl/libs/*.mod cfl/mpi/ Code:
make cfl3d_seq make cfl3d_mpi |
July 26, 2018, 06:09 |
#6 | |
William Tougeron
Rep Power: 15 |
Your method worked as well and seems to be cleaner than mine (especially because I removed lots of options that can be subsituted by other ones with your method). Just to say, the only makefile template I found was "makefile_mac_gfortran_example". Thank you very much for advices and experience sharing. All the best, |
December 22, 2020, 01:11 |
I got stuck while proceeding the installation of CFL3D in Linux V16. Kindly help me
velumani
We have these files but file format is .F90 only. How can I convert this .F90 to .mod ?
I am unable to copy-paste the following files from build/cfl/libs/ to build/cfl/mpi/ module_kwstm.mod module_profileout.mod module_contour.mod |
December 22, 2020, 01:37 |
velumani
we have completed the below steps while installing CFL3D in linux :
./Install mv ~/CFL3D/build/makefile ~/CFL3D/build/makefile.bu cp ~/CFL3D/build/makefile_mac_gnu ~/CFL3D/build/makefile I renamed the below files which actually was in .f90 format, I have changed to .mod manually, then I copy-pasted the following files from build/cfl/libs/ to build/cfl/mpi/ module_kwstm.mod module_profileout.mod module_contour.mod cp ~/Desktop/CFL3D/build/cfl/libs/*.mod ~/Desktop/CFL3D/build/cfl/seq/ cp ~/Desktop/CFL3D/build/cfl/libs/*.mod ~/Desktop/CFL3D/build/cfl/mpi/ We got stuck while executing the below commands make cfl3d_seq make cfl3d_mpi Getting the below error : ================================================== ============ compiling cfl3d_libs ================================================== ============ ( cd cfl/libs; make -f makefile cfl3d_libs \ FFLAG="-O2 -w -module /home/midhun/Desktop/CFL3D/build/cfl/libs " \ FFLAG_SPEC="-O2 -w -module /home/midhun/Desktop/CFL3D/build/cfl/libs " \ LFLAG="-z muldefs" \ EXEC="cfl3d_libs" \ CPPFLAG="-P" \ CPPOPT="-DP3D_SINGLE -DLINUX -DINTEL -DDBLE_PRECSN " \ AROPT="rusc" \ RANLIB="true" \ CPP="cpp" \ CFLAG="" \ LLIBS="" \ FTN="mpif90" \ DIR="cfl/libs" \ CFLSRC_S="../../../source/cfl3d/libs" \ CFLSRC_D="../../../source/cfl3d/dist" \ HEADER="../../../header" ) make[1]: Entering directory '/home/midhun/Desktop/CFL3D/build/cfl/libs' mpif90 -DP3D_SINGLE -DLINUX -DINTEL -DDBLE_PRECSN -O2 -w -module /home/midhun/Desktop/CFL3D/build/cfl/libs -c add2x.F make[1]: mpif90: Command not found makefile:129: recipe for target 'add2x.o' failed make[1]: *** [add2x.o] Error 127 make[1]: Leaving directory '/home/midhun/Desktop/CFL3D/build/cfl/libs' makefile:370: recipe for target 'Zlibs' failed make: *** [Zlibs] Error 2 |
October 29, 2022, 06:44 |
A makefile that works on Ubuntu linux
#9 |
# # $Id$ # #============================================================================= # # This is the primary/top-level makefile: builds either the parallel or # sequential versions of CFL3D, as well as the preprocessors PRECFL3D, # RONNIE, and MAGGIE and SPLITTER. Only sequential versions of # of MAGGIE AND RONNIE are currently available # # # cfl3dv6.0 directory structure: # # CFL3DV6.0 # | # ------------------- # | | | # SOURCE BUILD HEADER # | # -------------------------------------------- # | | | | | | # CFL3D PRECFL3D RONNIE MAGGIE SPLITTER TOOLS (source code archives) # | # ------- # | | # DIST LIBS # # # build directory structure: # # BUILD (you are here) # | # ---------------------------------------------------------------- # | | | | | | | | | # CFL CFLCMPLX PRECFL PRERON RON MAG TOOLS SPLIT SPLITCMPLX # | | | | | | | | | # --------- ---------- | | | | | | | # | | | | | | | | | | | | | # LIBS SEQ MPI LIBS SEQ MPI SEQ SEQ SEQ SEQ SEQ SEQ SEQ # # (bottom level of build is the "construction" level) # #============================================================================= # *************** COMPILER FLAG DEFINITIONS (MACHINE SPECIFIC) *************** # (CURRENT DEFINITIONS FOR LINUX ARCHITECTURE) FFLAG = -O2 -w -I$(MPILIB_INCDIR) -I$(MPI_INCDIR) -fallow-argument-mismatch /media/mohamedsereez/bigDisk/Software/CFL3D-master/build/$(CFLLIBSD) FFLAG_SPEC = -O2 -w -I$(MPILIB_INCDIR) -I$(MPI_INCDIR) -fallow-argument-mismatch /media/mohamedsereez/bigDisk/Software/CFL3D-master/build/$(CFLLIBSD) PREC = PREC_MPI = -DDBLE_PRECSN LFLAG = -z muldefs LLIBS = -lmpich LLIBS_SEQ = MPI_INCDIR = -I/usr/lib/x86_64-linux-gnu/mpich/include MPILIB_INCDIR =/usr/lib/x86_64-linux-gnu CGNS_INCDIR = CPP = cpp CPPFLAG = -P CPPOPT = $(MPI_INCDIR) -DDIST_MPI $(PREC_MPI) CPPOPT_SP = -DP3D_SINGLE -DLINUX -DINTEL -DNOREDIRECT $(PREC_MPI) $(CGNS_INCDIR) CPPOPT_CMPLX = -DCMPLX FTN = mpif90 CFLAG = AROPT = rusc RANLIB = true INLINE = # ********************** EXECUTABLE NAME DEFINITIONS ************************* EXEC_CFLSEQ = cfl3d_seq EXEC_CFLMPI = cfl3d_mpi EXEC_CFLLIBS = cfl3d_libs EXEC_PRESEQ = precfl3d EXEC_RONSEQ = ronnie EXEC_PRERONSEQ = preronnie EXEC_MAGSEQ = maggie EXEC_SPLIT = splitter EXEC_TOOLS = cfl3d_tools EXEC_CFLCMPLXSEQ = cfl3dcmplx_seq EXEC_CFLCMPLXMPI = cfl3dcmplx_mpi EXEC_CFLCMPLXLIBS = cfl3dcmplx_libs EXEC_SPLITCMPLX = splittercmplx # ********************** DIRECTORY NAME DEFINITIONS ************************* # ALL DIRECTORY PATHS RELATIVE TO THIS DIRECTORY (BUILD) # "CONSTRUCTION" DIRECTORIES (first-level directory names on right of the # equal signs below must be different than the executable names above, # or else make will think the executable is always up to date; e.g. if # EXEC_RONSEQ = ronnie then RONSEQD = ronnie/seq is not acceptable) CFLMPID = cfl/mpi CFLLIBSD = cfl/libs CFLSEQD = cfl/seq PRESEQD = precfl/seq RONSEQD = ron/seq PRERONSEQD = preron/seq MAGSEQD = mag/seq SPLITD = split/seq TOOLSD = tools/seq CFLCMPLXMPID = cflcmplx/mpi CFLCMPLXLIBSD = cflcmplx/libs CFLCMPLXSEQD = cflcmplx/seq SPLITCMPLXD = splitcmplx/seq # SOURCE-CODE DIRECTORIES - code changes must be made in these directories CFLSRC_D = ../source/cfl3d/dist CFLSRC_S = ../source/cfl3d/libs PRESRC = ../source/precfl3d RONSRC = ../source/ronnie PRERONSRC = ../source/ronnie MAGSRC = ../source/maggie SPLITSRC = ../source/splitter TOOLSSRC = ../source/tools # HEADER-FILE DIRECTORY HEADER = ../header # MAKEFILE OPTION - to process "if defs", use can either cpp built into the # fortran compiler or an explict call to an external cpp # # MAKEFILE = makefile ... use fortran cpp # = makefile_cpp ... use external cpp (may need to alter path # in the "CPP = " statement under "COMPILER # FLAG DEFINITIONS" above MAKEFILE = makefile |
cfl3d compile mpiifort |
Getting error both interpreting and compiling | serene6390 | Fluent UDF and Scheme Programming | 1 | October 27, 2017 00:49 |
CFL3D available on github | Martin Hegedus | Main CFD Forum | 4 | September 23, 2017 11:52 |
All files present. but solver not compiling | saddy | OpenFOAM Programming & Development | 1 | July 29, 2017 09:50 |
[OpenFOAM.org] Trouble Compiling OpenFOAM-dev using Intel Compiler 15 for use on Xeon Phi | foamer123 | OpenFOAM Installation | 9 | August 20, 2015 14:03 |
Help with KIVA4 source code compiling | geothokar | Main CFD Forum | 0 | September 3, 2010 05:40 |
