RANS equation for compressible transitional state flow |
August 10, 2018, 02:44 |
Antony Bidhan Biswas
As my undergraduate thesis is completely based on critical Reynolds Number region, can anyone give me proper mathematical analogy about Reynolds Average Navier Stoke equation to not able to solve in critical Reynolds Number region for compressible fluid? |
August 10, 2018, 11:54 |
Lucky
Rep Power: 66 |
RANS is just the mean momentum equation. Where RANS truly fails is where the concept of statistical averaging fails, e.g. when the mean is not unique. I can't think of any examples. The only one that comes to mind is if the flow becomes unbounded in finite time, which is currently the Millenium problem that we know does not have a proof. I don't have any examples of bounded variables with non-unique means. Put another way, when can we say that the mean momentum does not exist?
There are two caveats to RANS that are not really the fault of RANS. When you write down the RANS equations, Reynolds stresses appear. A proper description/prediction of the Reynolds stresses completely satisfies the problem. Question is whether you can accurately model these reynolds stresses or not. But usually when we say RANS we actually mean RANS with the Boussinesq eddy viscosity hypothesis. The reason for doing so is to rewrite the Reynolds stresses in terms of the velocity gradient. Now the issue is shifted a bit. Assuming the Boussinesq hypothesis works now all we need is a good prediction of the eddy viscosity. Question now is whether you can make this prediction or not. Note the validity of the Boussinesq hypothesis doesn't mean it represents the correct physics or not, it just simply means that for any given Reynolds stress, you can write down an eddy viscosity that gives you that Reynolds stresses using some magical equation that we don't even know yet. But if your turbulence model does not give you the right eddy viscosity or the right Reynolds stress, you get the wrong solution. This isn't a RANS problem but a turbulence modeling problem. The real question is whether your turbulence model is good enough or not? |
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow | Jing | Main CFD Forum | 8 | October 5, 2018 17:02 |
rhoSimpleFoam pressure P is not satisfy perfect gas state equation at inlet patch | fxzf | OpenFOAM Running, Solving & CFD | 0 | September 18, 2017 06:40 |
problem on energy and flow equation solving separately | preetam69 | FLUENT | 2 | July 30, 2013 21:08 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
About the difference between steady and unsteady problems | Lisa | Main CFD Forum | 11 | July 5, 2000 14:37 |
