September 22, 2018, 08:57 |
What Planform Area To Use For Airfoils?
Matt Ridzon
Rep Power: 11 |
I am doing airfoil work, calculating lift and drag coefficients with traditional lift and drag equations from fluid mechanics. To date, it has been my understanding that the planform area to use in the calculations should be the respective area in the specific direction; i.e., use the projected frontal area for drag calculation and use the projected top area for the lift calculation. Someone recently told me that was wrong for airfoil work. They said to instead use the projected top area for both calculations. Oddly enough, when I made this change in my work, I noticed more sensible results. Is this standard convention for airfoil work?
Thanks in advance! |
September 23, 2018, 01:25 |
It does not matter which area you use as long you as you stick to one convention and everybody uses this convention, both experiments and numerics, to tabulate the non-dimensional results. That way you can compare the results.
The purpose of non-dimensionalization is to generate results which apply to not just one airfoil but to a class of airfoils (at same Re) which are self-similar, that is they have same shape but scaled up or down (usually down because in a wind tunnel you use smaller models to fit in the tunnel but you dont have this restriction in numerics). Sometimes it can make physical sense to use a particular area. Wetted area is more relevant if drag is predominantly viscous. For high mach flows, drag may be dominated by pressure drag, then frontal area is more relevant for this phenomenon. Whatever area is used for drag/lift coefficients must be clearly stated and you must use same area to compare your results with other results. |
September 24, 2018, 08:04 |
#3 | |
Matt Ridzon
Rep Power: 11 |
I believe the overhead planform is used (view from above) for reporting both lift and drag, but I'm looking for confirmation from someone who has extensive airfoil background. |
problem "face 0 area does not match neighbour by xxx%" in parallel run | Aleigus | OpenFOAM | 0 | July 2, 2017 12:10 |
[OpenFOAM] Problem with cell area calculation in a slice | daniel87 | ParaView | 5 | October 24, 2015 16:18 |
Non overlap area fractions | saisanthoshm88 | CFX | 11 | September 17, 2015 18:42 |
CFX Solver Memory Error | mike | CFX | 1 | March 19, 2008 07:22 |
