September 27, 2018, 04:58 |
#21 | |
If u can see yourself working in the field of CFD in the future, this is the only way to go, since you are gonna work on clusters at some point, and most of them are with Linux (or maybe Unix? I am not sure about this one). Last edited by TurbJet; September 28, 2018 at 00:34. |
September 27, 2018, 05:59 |
#22 |
Filippo Maria Denaro
Rep Power: 71 |
I see a different perspective. As a professor, I would ask to my student if he want to be only a programmer! Working in CFD is not be only a good programmer, this is the last step of a path.
A good programmer can find easily a job in several fields if he knows Java, perhaps... Fortran or C++ depends also on what you want to program. HPC is an environment where Fortran is still largely used. On the other hand object-based programming is possible also in Fortran now. Then one should have care about the great advances in GPU-based programming. So my answer is to think first about if programming will be only a tool or a final goal for you. |
September 27, 2018, 06:27 |
#23 | |
Yusuf Elbadry
Rep Power: 7 |
i think it will be a tool for me , i am looking to be a code developer , i am looking forward to work in the simulation field as a programmer , so my aim isnt a code to solve one problem ( even if it is Big one ) . |
September 27, 2018, 06:31 |
#24 | |
Yusuf Elbadry
Rep Power: 7 |
September 27, 2018, 06:32 |
#25 |
Yusuf Elbadry
Rep Power: 7 |
September 27, 2018, 06:44 |
#26 | |
Rep Power: 71 |
In CFD field we can generalize two general jobs, research & development (academy and industry) and engineering-applied job, basically be an end-user of some commercial (or sometimes open source) code. The former requires often much more than being a good programmer and is a path that often requires a PhD training. The latter requires no or few programming job (just using some C++ knowledge for UDF functions). OpenFOAM can be a challenge for the requirement of being a good C++ programmer but only if you want do develop your own model. Again, a good programmer (Fortran or C++) can also be a person that has no knowledge at all of CFD. |
September 27, 2018, 06:49 |
#27 | |
Yusuf Elbadry
Rep Power: 7 |
so i think i will go first for the academic path beside that i looking to be a good programmer . i still think in both language , C++ or Fortran , but i think i am started to be more close to C++ as many says that it will learn me to be a part of a big system , and some said no one writes good fortran codes , it is ugly to reuse or to edit it . what do you recommend me , linux or windows ? |
September 27, 2018, 06:54 |
#28 | |
Rep Power: 71 |
Linux. I used to install CentOS but I don't know if at present you can find some better project. |
September 27, 2018, 07:07 |
#29 |
September 27, 2018, 07:17 |
#30 | |
Santiago Lopez Castano
Rep Power: 15 |
All this comments comparing/saying that fortran/C is dead, and C++ is the panacea, speak of the ineptitude of the commenter in PROGRAMMING FOR CFD. If someone tells me that implementing a parallel structured grid solver in pure C++, instead of FORTRAN/C, is better, clearly doesnt know what he's talking. The origin of this "debate" came with the emergence of OpenFOAM and other all-purpose open libraries for CFD. It created an aurea of "superior morality" for C++, without actual evidence that supports it |
September 27, 2018, 07:40 |
#31 |
Please note that knowing Fortran doesn't prevent you from actually knowing other languages.
Knowing both is probably the most productive choice in the long run. Like having a boat and a car. Use one for water and the other for land. Not really an headache matter here. Just choose which one to pick up first. |
September 27, 2018, 08:39 |
#32 | |
Yusuf Elbadry
Rep Power: 7 |
if you are going to advise me directly , which language would you recommend ? as i said i will start from scratch and i am free to choose . i dont know anything about fortran , just small things about c++. i am looking for a long run career , not just a problem for master or PhD . time for learning isnt a problem i still have a time . |
September 27, 2018, 08:40 |
#33 | |
Yusuf Elbadry
Rep Power: 7 |
so if i am your student , what will you recommend , c++ or fortran ? |
September 27, 2018, 08:50 |
#34 | |
Arjun
Rep Power: 34 |
Ansys has many softwares and most of them are C++ or C based. For example CFX is fortran based and Fluent is C based. It is very likeky that CFX is fading away. Adapco came out fortran based starCD to move to C++ based Starccm+ exactly for the reasons i mentioned. In fact the fact that Fluent is C based put Ansys at big disadvantage compared to Starccm+ in terms of development for various physics. I chose C++ the same reason for Wildkatze and in 2 to 3 years you can see the amount of features it presents is pretty good. I can't even dream of fraction of development with FORTRAN. I personally would never chose fortran as language for development for any of my projects. |
September 27, 2018, 08:52 |
#35 | |
Arjun
Rep Power: 34 |
I actually code in fortran for others if I am required to code for their projects. I don't care much because it is another language. Not my choice but i don't say i can't do because of language. I just code in any language that is requirement at that time. |
September 27, 2018, 08:54 |
#36 | |
Rep Power: 15 |
Modern fortran, and C, support OOP, classes, inheritance, polymorphism. It is certainly the case that C++ is somewhat richer in this aspect and, to some level, the standard library is efficient. You'll be better served using linked lists for the description of the grid topology if the comprising elements are polyhedra. Cell-to-face associations are easily made through pointers which, for the languages just listed, are available. If you plan to do a structured solver, you may be better served with languages that support array operations DIRECTLY. In C you'll have to play a bit with pointer arithmetics, whereas in fortran is ready to go. In the case of C++ you have to use libraries which will reduce the performance and will make the code unnecesarily complex... |
September 27, 2018, 08:55 |
#37 | |
But now I read you know some C++. In this case you should go C++ first. It is that simple, because both are more than capable of everything you need to work in computational physics at any sophistication level. The single real point against Fortran today is availability of free compilers under Windows and their coupling with MPI. Everything is easily doable but it all leaves you with that strange feeling of a hack instead of a fresh out of the box solution as it is under linux. |
September 27, 2018, 13:18 |
#38 | |
andy
Rep Power: 17 |
Mastering C++ and HPC Fortran is an appropriate task as part of a CFD PhD but much less so as part of a CFD MSc especially if you need to teach yourself the language and even more so if it is only needed to support the taught element. If you have used matlab as part of your undergraduate course then Fortran will require the least amount of effort to support your MSc studies. C will require more effort but if you intend to use C++ as part of your PhD studies then it might be the better choice. The problem with C++ is that it's poor design requires one to learn a great deal more than what the statements do if you are to avoid writing poor programs. This can be done but it takes time and experience which you won't have on a typical intensive CFD MSc where the objective is to learn about CFD and not programming in a difficult language. PS. An operating system isn't particularly important in itself but what packages are available can be. If you are familiar with Windows and the programs and libraries you need for the CFD MSc are available then I would be tempted to leave learning about Linux for a PhD when there will be more time for this type of learning. Last edited by andy_; September 27, 2018 at 13:26. Reason: PS |
September 28, 2018, 12:26 |
#39 |
Yusuf Elbadry
Rep Power: 7 |
Many thanks to all of you
really i got many information from you I will start my journey to learn C++ and how to deal with Linux , i am looking far as i see that C++ will be a better choice in the future . You are very helpful and very informative , thanks again !! |
September 28, 2018, 12:47 |
#40 | |
Rep Power: 71 |
As CFD is your main goal as student, try to learn C++ directly coding simple standard numerical test used in CFD: advection-difusion equation in FD and FV methods, iterative methods, time integration and so on. When you get quite ready, you could try to understand how OpenFOAM works for solving the NS equations. An interesting reading in this case would be https://www.google.it/imgres?imgurl=...CpIQ_B0IiAEwCg |
User fortran to input/output file in a parallel run | doublestrong | CFX | 5 | March 31, 2017 08:15 |
Fortran Compiler-CFX12.1 | Araz | CFX | 13 | March 27, 2017 05:37 |
CFD Code Conversion from Intel Fortran to GNU Fortran | pitto | Main CFD Forum | 4 | August 4, 2016 14:51 |
Using Fortran with CFX: How to connect Fortran to CFX? | l.te | CFX | 0 | October 21, 2012 11:42 |
visual fortran | Monica | Main CFD Forum | 1 | August 28, 2004 20:45 |
