LUSGS vs GMRES
Like Tree9Likes
  • 1 Post By AshwaniAssam
  • 1 Post By Jonas Holdeman
  • 1 Post By sbaffini
  • 3 Post By KingJGod
  • 2 Post By enm
Old   November 16, 2018, 08:04
Default LUSGS vs GMRES
Ashwani
AshwaniAssam is on a distinguished road
Dear all,
We have an implicit code for which we have used LUSGS method, based on the use of LU-decomposition algorithm from the Numerical recipe book. When we are trying to use an iterative method like GMRES, for some cases the code is blowing up like hypersonic flow over a cylinder. While for some like compressible flow over bumpit gives exact same residual drop as LUSGS.
We have verified the GMRES implementation against the solution to Linear system of equations. We have used Numerical recipe book again for GMRES algorithm.
Any thoughts what possible is wrong in our implementation or understanding?
Thank you!
aerosayan likes this.
AshwaniAssam is offline   Reply With Quote
Old   November 16, 2018, 11:19
Jonas T. Holdeman, Jr.
Jonas Holdeman is on a distinguished road
I have had trouble using GMRES with incomplete LU preconditioner (actually with the LU preconditioner) in MATLAB. I am quite happy now using the stabilized biconjugate gradient with Jacobi preconditioner. I am not familiar with the LUSGS method.
Jonas Holdeman is offline   Reply With Quote
Old   November 18, 2018, 10:15
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
There are several linear algebra packages with the GMRES (petsc, hypre, etc.), I would refer to those for the implementation.
sbaffini is offline   Reply With Quote
Old   January 9, 2020, 12:13
youcheng xi
KingJGod is on a distinguished road
Generally speaking, this is probably because of your preconditioner and the accuracy of your numerical jacobian evaluation
KingJGod is offline   Reply With Quote
Old   January 13, 2020, 12:09
enm
Nick
enm is on a distinguished road
I think the main problem is a preconditioner or the matrix itself (Jacobian) as KingJGod stated.
Here is how i use it:
https://www.sciencedirect.com/scienc...21999119308940
And there's no problem with gmres or bcgstab.
AshwaniAssam and aerosayan like this.
enm is offline   Reply With Quote
Old   January 17, 2020, 00:57
Ashwani
Thank you KingJGod and enm for the answer. I also suspect that. Recently, i have started using LIS library. I will try to use the preconditioner which I was not using earlier. I will report back how things work.
Again thank you, and enm thank you sharing the JCP work it will be very helpful.
Gmres OFU OpenFOAM Programming & Development 11 November 3, 2015 09:08
SU2 runtime error: cannot find value of GMRES in given map bruzerravi SU2 1 May 1, 2013 08:11
Gmres fails to converge, but LU is fine sbabbi Main CFD Forum 1 April 11, 2013 09:54
Question on ILU(0) Preconditioned GMRES Shenren_CN Main CFD Forum 2 August 6, 2012 20:19
Nonlinear/Linear GMRES is... Saebyuk Main CFD Forum 0 May 10, 1999 09:31
