john
Rep Power: 10 ![]() |
I want to model the temperature increase within a gun's muzzle device due to the flow of the hot propellant gases after a projectile is fired. The gas flow will be transient. I have used ANSYS for structural analyses and for CFD analysis of flow around a projectile to evaluate aerodynamic coefficients, but not for heat transfer into a 3D body within a hot gas flow. What would be the best software approach to solve this problem? Fluent, CFX, or ?? I already have the 3D model of the muzzle device and for the end result I want the temperature profile throughout the 3D solid, not just a surface temperature. Thanks.
Lucky
Rep Power: 66 ![]() ![]() ![]() |
Fluent and CFX both work. Use whichever you prefer. Preferably, use the same program that you used for the aero analysis.
moving a cold solid body into stationary hot air for heat transfer | shyamgarg | Main CFD Forum | 3 | December 26, 2019 22:41 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Thermally coupling 1D gas flow to 3D heat conduction in solid | Pyotr | CFX | 5 | March 6, 2017 21:46 |
High values of heat transfer coefficient for laminar flow in pipe | Allankey | CFX | 2 | May 28, 2014 12:44 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
