March 28, 2019, 09:35 |
heat transfer from hot gas flow to solid
john
Rep Power: 10 |
I want to model the temperature increase within a gun's muzzle device due to the flow of the hot propellant gases after a projectile is fired. The gas flow will be transient. I have used ANSYS for structural analyses and for CFD analysis of flow around a projectile to evaluate aerodynamic coefficients, but not for heat transfer into a 3D body within a hot gas flow. What would be the best software approach to solve this problem? Fluent, CFX, or ?? I already have the 3D model of the muzzle device and for the end result I want the temperature profile throughout the 3D solid, not just a surface temperature. Thanks.
March 28, 2019, 09:58 |
Lucky
Rep Power: 66 |
Fluent and CFX both work. Use whichever you prefer. Preferably, use the same program that you used for the aero analysis.
moving a cold solid body into stationary hot air for heat transfer | shyamgarg | Main CFD Forum | 3 | December 26, 2019 22:41 |
Thermally coupling 1D gas flow to 3D heat conduction in solid | Pyotr | CFX | 5 | March 6, 2017 21:46 |
High values of heat transfer coefficient for laminar flow in pipe | Allankey | CFX | 2 | May 28, 2014 12:44 |
