The division of Reynolds number for flow around airfoil |
April 10, 2019, 02:07 |
Jiadong Wang
Rep Power: 8 |
I’m working on the flow around the oscillating foils, in which the fluid is water. I found lots of posts include the terms “low Reynolds number” “high Reynolds number”. But none of them give the absolute range for these terms.
That’s what I’m confused. So for the problem of flow around a NACA foil, which range of Reynolds number can be called low Re? Which range Reynolds number can be called high Re? And which range can be called medium Reynolds number? Thank you. |
April 10, 2019, 09:12 |
Lucky
Rep Power: 66 |
Low and high are subjective and relative. If they don't mention any specific number referring to a specific flow situation then there is no meaning to it. This is not a Starbucks or fast food restaurant where you have small, medium, and large sized servings.
April 10, 2019, 19:32 |
#3 | |
Jiadong Wang
Rep Power: 8 |
You are definitely right. I found such idea in other posts. |
airfoil, reynolds number |
2D simulation of a Transonic Airfoil at high Reynolds number | ClAuDi0 | STAR-CCM+ | 1 | November 18, 2018 14:25 |
[mesh manipulation] Mesh Refinement | Luiz Eduardo Bittencourt Sampaio (Sampaio) | OpenFOAM Meshing & Mesh Conversion | 42 | January 8, 2017 12:55 |
Reynolds number in 2D airfoil simulation | jck | OpenFOAM Running, Solving & CFD | 2 | June 3, 2016 03:56 |
[OpenFOAM.org] OF2.3.1 + OS13.2 - Trying to use the dummy Pstream library | aylalisa | OpenFOAM Installation | 23 | June 15, 2015 14:49 |
