May 11, 2019, 18:44 |
Energy equation in weird format
anonymous
Rep Power: 8 |
Hi everyone,
I am confused on the NS and RANS format of the energy equation (attached below) I do not understand why there are only two terms on the LHS of the equation. The first term on the LHS represents the Fourier law of thermal conductivity. I have researched and found that q''' represents the volumetric heat generation. I cannot find any equation online that bears similar resemblance. Also, Why is the thermal conductivity term expanded to produce a 'Reynolds stress' for the energy equation? I am presuming a model like the mixing length model will interpret this the same way as it would for a momentum Reynolds stress term. If anyone can explain the terms in these equations, you are a true CFD genius!!!! Any help much appreciated. |
May 12, 2019, 04:22 |
Filippo Maria Denaro
Rep Power: 71 |
The term q''' seems just a production term in the internal energy equation, for example due to chemical reaction.
The RANS equations are deduced when you introduce the decomposition of temperature and velocity in average and residual terms. The convective terms produces the unresolved term that must be modelled. For the temperature equation it can be debated that a eddy diffusivity-like term is physically meaningful |
May 12, 2019, 07:16 |
anonymous
Rep Power: 8 |
Thank you for the response kind sir.
So is it safe to say then the turbulence models are used to solve the 'reynold stress' in the energy equation. As I cannot seem to find any models that solve the blue part in the energy equation Regards |
May 12, 2019, 07:21 |
#4 | |
Rep Power: 71 |
In the internal energy equation the unresolved terms are a stress-like term as in the momentum equation. They are often modelled a a supplementary heat flux. Have a look to the book of Wilcox. |
May 12, 2019, 07:28 |
anonymous
Rep Power: 8 |
I have read some literature that describes the temperature term in the RANS as a turbulent stress. I will look at the book to see if i can find a derivation of how a turbulence model interprets the energy equation
Thank you for the quick response |
May 13, 2019, 00:39 |
Lucky
Rep Power: 66 |
The 1st term on the RHS of the Reynolds averaged equation looks very similar to the original term in the time-accurate equation (the red term) except with instead of . The blue term actually comes from the 2nd term on the left hand side. It has nothing to do with thermal conductivity. That is, start with:
Put and and then take the Reynolds average and the blue term will pop out. The negative (minus sign) comes from moving this term from the LHS to the RHS. The blue term is modeled most commonly using a turbulent Prandtl number and most often using a constant turbulent Prandtl number which is slightly less than 1. Also these are not weird forms for the energy equation, this is how it is supposed to look. =) Whatever sources you use might derive one or more variants of the RANS, but it is very standard. Not weird. I've personally written down this equation on napkins probably a hundred times and thrown them into the wastebin. |
Energy equation - where is the turbulent kinetic energy? | usv001 | OpenFOAM Programming & Development | 1 | January 25, 2022 15:04 |
Fluent do not use my velocity field(by UDF) to solve energy equation | tangleiplus | Fluent UDF and Scheme Programming | 6 | January 21, 2019 21:28 |
Comparing residuals of momentum and energy equation | skarma | FLUENT | 4 | November 25, 2017 22:03 |
Error in computing Energy equation | faab | OpenFOAM Running, Solving & CFD | 0 | February 3, 2017 13:04 |
SIMPLE and energy equation convergence | Fabio | Main CFD Forum | 0 | June 1, 2007 06:06 |
