Using steady state for Transient Initialization |
September 13, 2019, 21:44 |
Soumitra Vadnerkar
Rep Power: 7 |
How will the convergence of steady state simulation of a problem will affect its transient simulation if used for initialization?
September 14, 2019, 03:59 |
Too vague.
In general, if you plan to use the same turbulence modeling approach in both steady and unsteady (laminar/DNS or RANS/URANS) then, if the steady solution makes any sense, you don't need the unsteady one. If using RANS to initialize LES/DNS, you probably want almost converged mass fluxes and a good enough distribution of the turbulent quantities used to initialize the fluctuations Last edited by sbaffini; September 14, 2019 at 06:09. |
September 14, 2019, 04:02 |
Filippo Maria Denaro
Rep Power: 71 |
Paolo addressed the main issues.
Just to add that if you have a steady flow problem and you run a transient formulation starting from the initial steady numerical solution, you should find the code stops immediately as it reached the correct solution. |
initialization, steady state, transient |
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 21:43 |
Effect of initial condition for steady state vs Transient | prasa | ANSYS | 0 | August 22, 2018 04:45 |
Domain Reference Pressure and mass flow inlet boundary | AdidaKK | CFX | 75 | August 20, 2018 05:37 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
About the difference between steady and unsteady problems | Lisa | Main CFD Forum | 11 | July 5, 2000 14:37 |
