March 7, 2020, 09:54 |
FSI diffusion Terms
Vignesh
Rep Power: 6 |
Hello!!
I am solving a FSI problem. In this regard, I used a realisable k-epsilon model for solving the problem. In ANSYS Fluent solver, METHODS section which are all diffusion terms and which are all convection terms? so that I can specify the methods to them as per the journal I referred. I have also attached the screen shot of the journal image with this. Thank You Schemes1.jpg |
March 11, 2020, 12:17 |
Lucky
Rep Power: 66 |
Diffusion terms are always central differenced, you don't need to do anything and there is no option to change it anywhere.
In the Fluent GUI, the convective terms are specified in Solution Methods under Spatial Discretization. They have names like Momentum, Energy, Turbulent Kinetic Energy and so on. These are the convective terms. The default for the momentum equation and energy equation is second order upwind. Unless you solve additional turbulence models and so on, you don't need to do anything. It's still a good idea to verify it though. |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
implementation of diffusion coefficients and use of diffusion coefficients | stephan | OpenFOAM Running, Solving & CFD | 0 | February 28, 2010 14:30 |
BCs in an FSI simulation of a flexble pipe | vivekcfd | OpenFOAM | 10 | January 8, 2010 04:14 |
Question in definition of terms in solve | titio | OpenFOAM Running, Solving & CFD | 0 | March 19, 2009 16:02 |
fsi | sun | Siemens | 8 | January 19, 2009 23:17 |
