Linear variation of gradient of a scalar in a cell.
Like Tree2Likes
  • 1 Post By FMDenaro
Old   March 15, 2020, 08:45
Default Linear variation of gradient of a scalar in a cell.
Mandeep Shetty
granzer is on a distinguished road
If the temperature (or any scalar) is varying linearly in a cell, will the variation of the gradient of the temperature also be linear?
If we say that temperature, T, is varying linearly in a square plate given by
T = Tp +(x-xp)grad(Tp)
where Tp is the Temperature at the centroid of the square plate, xp is the centroid, x is any point on the plate so (x-xp) is the position (so a vector) of any point on the plate from the centroid, grad(Tp) is the temperature gradient at the centroid.
Is it correct to write,
a) grad(T) = grad(Tp)+(x-xp)grad(grad(Tp))
as (x-xp), even though is a vector, doesn't actually change with x,y,z
OR
b) grad(T) = grad(Tp)+grad[(x-xp)grad(Tp)]
as we cannot consider (x-xp) to be a constant with respect to x, y, z.
Ref: Prof.Hrvoje Jasak Thesis, Error Analysis and Estimation for the Finite Volume Method with Applications to Fluid Flows
granzer is offline   Reply With Quote
Old   March 15, 2020, 10:53
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
OR
Once the temperature is assumed linear, its derivative is a constant in the cell:
T(x)=T0+T1*x -> dT/dx=T1
FMDenaro is offline   Reply With Quote
Old   March 15, 2020, 13:11
Mandeep Shetty
Thank you! If I assume the gradient of temperature itself to vary lineraly can i write
grad(T) = grad(Tp)+(x-xp)grad(grad(Tp))?
Old   March 15, 2020, 13:16
Well, be careful that grad is also a vector operator. Work on the components dT/dx and dT/dy. But this way you are assuming a quadratic law for the temperature
granzer likes this.
Old   March 15, 2020, 13:26
Mandeep Shetty
I am trying to use a second-order FVM method. I was told that using the second-order FVM method means all the variables (which I am starting to understand just means the primitive variables and not the gradient of the said variables) would be assumed to vary linearly within the cell. So as I am already assuming the temperature to vary linearly, and so I cannot assume the grad(T) to vary linearly again.
Old   March 15, 2020, 13:41
Indeed in a FVM you have a second order accuracy using a linear assumption for the function. The derivative is constant on each of the face so that you can evaluate their difference
granzer likes this.
finite volume calculus, gradient
Periodic flow using Cyclic - comparison with Fluent nusivares OpenFOAM Running, Solving & CFD 30 December 12, 2017 05:35
Neighboring cells in tetrahedral mesh vishwesh OpenFOAM Programming & Development 9 November 10, 2017 07:06
Diverging solution in transonicMRFDyMFoam tsalter OpenFOAM Running, Solving & CFD 30 July 7, 2014 06:20
FvMatrix coefficients shrina OpenFOAM Running, Solving & CFD 10 October 3, 2013 14:38
is internalField(U) equivalent to zeroGradient? immortality OpenFOAM Running, Solving & CFD 7 March 29, 2013 01:27
