Flow Direction NOT normal To Boundary critical? |
April 20, 2020, 07:33 |
Rep Power: 10 |
I am simulating an aircraft foil. My fluid domain is a sphere. For the sphere I specified "pressure far field" with an inlet velocity of Mach=0.8 In order to simulate an angle of attack of the airfoil, I specified the direction vector coming from x=0.707 , y=0 , z=0,707 (45° degree). Do you think this might cause problems for the convergence since flow is not coming normal to the boundary surface? Thanks for your comments CellZone! |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
Flow Direction: normal to boundary!!! | Atit | CFX | 1 | August 2, 2015 13:42 |
Low torque values on Screw Turbine | Shaun Waters | CFX | 34 | July 23, 2015 08:16 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
[snappyHexMesh] determining displacement for added points | CFDnewbie147 | OpenFOAM Meshing & Mesh Conversion | 1 | October 22, 2013 09:53 |
