Time spectral method
Old   June 23, 2020, 21:29
Post Time spectral method
Abhi Chopra
ChopraAbhi is on a distinguished road
I'm interested in the applying time spectral method to the discontinuous-galerkin finite element based CFD (https://pdfs.semanticscholar.org/618...0f7a92b1d2.pdf). I came across a spectral element method and was wondering if it has the time spectral component in it?
ChopraAbhi is offline   Reply With Quote
Old   June 24, 2020, 07:28
Eifoehn4's Avatar
Eifoehn4 is on a distinguished road
Could you rephrase your question or be more specific?
Check out my side project:
A multiphysics discontinuous Galerkin framework: Youtube, Gitlab.
Eifoehn4 is offline   Reply With Quote
Old   June 24, 2020, 08:21
Abhi Chopra
Sorry for not being clear. I was wondering if in spectral element method, does the time discritization takes the form of time spectral method described in the above paper? Is there something like pseudo-spectral method where space discritization is done in galerkin / DG framework and time can be done in spectral framework? Whatever paper I have read usually does time spectral in FVM (mainly) or FDM, not came across implementation in FEM. I hope I'm clear this time.
Old   June 24, 2020, 09:50
Eifoehn4's Avatar
The time discretization you mentioned in the paper is not standard at all and quite specific.
Generally explicit discretizations of spectral collocation/Galerkin (continuous or discontinuous) methods are equiped with one-step methods like Runge-Kutta (strong-stability preserving and/or low storage) or multi-step methods like Adams–Bashforth.
Moreover there are some groups which apply the idea of Lax-Wendroff or Cauchy-Kovalevskaya by using a space-time Taylor polynomial. This results in e.g. ADER-DG methods.
Regards
Elastic or Plastic Deformations in OpenFOAM NickolasPl OpenFOAM Pre-Processing 36 September 23, 2023 08:22
Time Spectral Method in SU2 Rachit SU2 2 July 14, 2015 16:24
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
same geometry,structured and unstructured mesh,different behaviour. sharonyue OpenFOAM Running, Solving & CFD 13 January 2, 2013 22:40
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
