June 23, 2020, 21:29 |
Time spectral method
Abhi Chopra
Rep Power: 5 |
I'm interested in the applying time spectral method to the discontinuous-galerkin finite element based CFD (https://pdfs.semanticscholar.org/618...0f7a92b1d2.pdf). I came across a spectral element method and was wondering if it has the time spectral component in it?
June 24, 2020, 08:21 |
Abhi Chopra
Rep Power: 5 |
Sorry for not being clear. I was wondering if in spectral element method, does the time discritization takes the form of time spectral method described in the above paper? Is there something like pseudo-spectral method where space discritization is done in galerkin / DG framework and time can be done in spectral framework? Whatever paper I have read usually does time spectral in FVM (mainly) or FDM, not came across implementation in FEM. I hope I'm clear this time.
June 24, 2020, 09:50 |
Rep Power: 13 |
The time discretization you mentioned in the paper is not standard at all and quite specific.
Generally explicit discretizations of spectral collocation/Galerkin (continuous or discontinuous) methods are equiped with one-step methods like Runge-Kutta (strong-stability preserving and/or low storage) or multi-step methods like Adams–Bashforth. Moreover there are some groups which apply the idea of Lax-Wendroff or Cauchy-Kovalevskaya by using a space-time Taylor polynomial. This results in e.g. ADER-DG methods. Regards |
Elastic or Plastic Deformations in OpenFOAM | NickolasPl | OpenFOAM Pre-Processing | 36 | September 23, 2023 08:22 |
Time Spectral Method in SU2 | Rachit | SU2 | 2 | July 14, 2015 16:24 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
same geometry,structured and unstructured mesh,different behaviour. | sharonyue | OpenFOAM Running, Solving & CFD | 13 | January 2, 2013 22:40 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
