June 26, 2020, 09:35 |
How STARCCM computes turbulent viscosity
MA
Rep Power: 6 |
Hi everyone,
I was wondering to know how CCM+ computes the turbulent viscosity (to be specified in initial conditions before running a simulation); I have checked the link https://www.cfd-online.com/Wiki/Turb...ary_conditions where it requires to have epsilon and turbulence length scale but I only have the free-stream turbulence and free-stream velocity. However, I looked into CCM+ manual where it defines a model "Turbulent Viscosity User Scaling" I think it is mainly for scaling the already known turbulent viscosity. I need this turbulent viscosity to define the viscosity ratio and other boundary conditions as given in the above link. Thanks for your time. |
June 26, 2020, 13:12 |
Lucky
Rep Power: 66 |
The turbulent viscosity ratio is in the initial conditions, not the turbulent viscosity. But what is actually needed as an initial condition and boundary conditions is the k and epsilon or k and omega. Turbulence intensity, length scale, and viscosity ratios are just convenience features provided to eventually calculate k and epsilon/omega.
June 26, 2020, 14:04 |
#3 | |
MA
Rep Power: 6 |
For instance, Re is the Reynold at full scale and turbulence intensity is 7%. Whereas, in my simulation I am using Re/10 and Turbulence Intensity = 1%. How should be my choice for Turbulent Velocity Scale and Turbulent Viscosity Ratio because STARCCM+ does not ask directly for k and omega values but viscosity ratio and turbulent velocity scale (using K-Omega SST model). Also, I have referred a paper on this - where Menter suggested to use following equations to calculate turbulent viscosity ratio, K and omega (see page no: 6): http://cfd.mace.manchester.ac.uk/twi...2554-CP.PS.pdf omega = constant*V/L Nu_t = 10^-3*Nu K = Nu_t*Omega I did the calculations as attached. Do you think I should specify these values for turbulent viscosity ratio and turbulence velocity scale as computed below? Thanks for your time. |
turbulent viscosity in k-e model | orlik | Fluent UDF and Scheme Programming | 1 | July 19, 2017 12:27 |
[OpenFOAM] turbulent viscosity ratio | bmikuz | ParaView | 2 | July 4, 2014 02:59 |
k-epsilon problem: non-physical turbulent viscosity production in coaxial free-jet | Felipeb | Main CFD Forum | 1 | July 26, 2010 17:02 |
Turbulent viscosity and shear rate | shib | FLUENT | 0 | June 22, 2010 12:44 |
Turbulent viscosity in a riser | ap | FLUENT | 8 | April 19, 2003 08:00 |
