Postprocessing flowRatePatch
Old   September 11, 2020, 02:59
Default Postprocessing flowRatePatch
hityo is on a distinguished road
Hello Foamers,
Inlet patch area is x and outlet is y. So from that the FlowRate in postprocessing should be different. In Paraview the results justify the Continuity equation but In Postprocessing flowRatePatch the results are same for Inlet and Outlet. Why??
What mistake I'm doing?
Thanks in advance!!!
hityo is offline   Reply With Quote
Old   September 11, 2020, 03:53
Joko is on a distinguished road
Why should the flowRate be different?
The flowRate is the volume what get into your simulation space and the continuity equation says the same volume has to go out of your simulation space. The unit of the flowRate is m³/s. Or am I wrong here?
I think you have evaluated the integrated velocity (m/s) over the patch in Paraview and not the flowRate. Is that possible?
Joko is offline   Reply With Quote
flowratepatch, openfoam 1.7.x, postprocessing; openfoam;
using fieldAverage library to average postprocessing eelcovv OpenFOAM Programming & Development 32 May 17, 2022 09:55
Do postProcessing via PyFoam shaoyx OpenFOAM Post-Processing 0 January 15, 2020 16:01
flowRatePatch error: Region has no faces gea OpenFOAM Post-Processing 4 September 4, 2018 13:50
Problem with flowRatePatch unifor OpenFOAM Running, Solving & CFD 0 April 19, 2016 11:40
Question about Postprocessing Using UDF(in tutoria sarah_ron2002 FLUENT 1 April 10, 2007 16:17
