March 29, 2021, 12:46 |
Vortex Method Inlet BC for LES
Nima
Rep Power: 11 |
Hi everyone
Does anyone know how to calculate the number of Vortices in Vortex Method Velocity Inlet bc in LES simulation? I read somewhere that it should be (Number of Facets at inlet)/4 which is too much (more than 1000) in my case. I’d appreciate any help |
March 29, 2021, 13:40 |
Rep Power: 7 |
Number of faces/4 makes sense because smallest eddy that can be resolved in 2D mesh needs 4 cells.
March 29, 2021, 16:24 |
Nima
Rep Power: 11 |
March 29, 2021, 16:41 |
Kira
Rep Power: 8 |
March 29, 2021, 16:44 |
Nima
Rep Power: 11 |
March 30, 2021, 04:59 |
There isn't, to the best of my knowledge, any paper discussing this with the proper theoretical rigor, or probably discussing this at all.
In general, reasoning on the grid resolution alone is not rock solid, for the simple reason that such vortex methods have also a prescribed size , which can be assigned independently from the grid resolution. Also, the vortex positions are random, so you can't actually control anything at the local level as the Nfaces/4 rule might seem to suggest. One approach I have seen is to use something like: where you basically assume that, on average, the inlet face is covered by vortices. You should instead adapt to the grid resolution. But, again, this requires more than simply reasoning on a pure number. Different schemes will require different resolutions, but sometimes a magic number exists that makes things work even if they shouldn't. So, in conclusion, N is not directly linked to the resolution. Indeed, some have found reasonable solutions with a fixed number O(100). |
March 31, 2021, 11:24 |
Nima
Rep Power: 11 |
UDF for inlet temperature and species concentration | haidory | Fluent UDF and Scheme Programming | 18 | September 1, 2019 04:57 |
interFoam wave propagation and explosion of Courant number and residuals | ChiaraViola | OpenFOAM Running, Solving & CFD | 1 | June 26, 2019 05:36 |
Are there any reasons why Vortex Method doesn't perturb the flow using SAS | kingjewel1 | FLUENT | 0 | June 1, 2018 11:42 |
LES Vortex Method by Mathey/Sergent | MrFrog | OpenFOAM Running, Solving & CFD | 3 | January 20, 2016 07:20 |
Vortex method vs High Reynolds number | Weili | Main CFD Forum | 1 | August 4, 2006 01:15 |
