Plotting streamlines on a sliding mesh
Like Tree1Likes
  • 1 Post By JBeilke
Old   July 18, 2021, 02:17
Default Plotting streamlines on a sliding mesh
Odisha
Siba11 is on a distinguished road
How to import 'x-velocity' and 'y-velocity' data into Tecplot-360, and draw streamlines?
I am using a sliding mesh to simulate flow past a rotating elliptic cylinder in ANSYS. When I import the case & data file into Tecplot and try to draw the streamlines, they break at the interface of the stationary and rotating domain. I have attached an image of the problem I am facing.
I am given to understand that importing just the 'x-velocity' and 'y-velocity' data will resolve this problem, but I don't know how to go about it. I'd be grateful if anyone could elucidate how to import the files, and what to do once they are imported in Tecplot.
I viewed this video on youtube- "Tecplot 360 Interpolation". But when I tried it, my cylinder disappeared, so it wasn't much help.
PS: I have Tecplot 360 EX 2014.
Siba11 is offline   Reply With Quote
Old   July 18, 2021, 06:12
Sayan Bhattacharjee
aerosayan is on a distinguished road
-deleted-
didn't read the question correctly before answering...
apologies...
aerosayan is offline   Reply With Quote
Old   July 18, 2021, 22:48
Kira
aero_head is on a distinguished road
What post processing software are you using (Fluent, CFX, etc...)?
aero_head is offline   Reply With Quote
Old   July 19, 2021, 00:51
Odisha
Hi, I'm using Fluent.
Old   July 20, 2021, 02:43
Kira
Okay, what format are you outputting the data as to Tecplot?
Old   July 20, 2021, 05:53
Joern Beilke
JBeilke is on a distinguished road
You can not do it with "Streamlines", because they have no meaning in a transient calculation. When you use the "absolute velocity" at a fixed time, the lines will usually hit the rotating wall, since in reality it has already moved.
Just do a transient particle tracking instead. Here is an example, that I did some time ago in EnSight (and also in StarCCM+) . But it should be also possible in Fluent.
https://www.beilke-cfd.de/files/vide...umeco_1280.mp4
aerosayan likes this.
JBeilke is offline   Reply With Quote
Old   July 21, 2021, 08:20
Odisha
I am loading the case and data file of Ansys Fluent 2019R3 into TecPlot 2014.
Getting divergence in dynamic mesh but not sliding mesh niamhiefitz FLUENT 0 April 20, 2021 06:08
Dynamic Mesh and Sliding Mesh Simultaneously reynold92 FLUENT 2 May 9, 2015 15:26
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 09:03
