July 18, 2021, 02:17 |
Plotting streamlines on a sliding mesh
Odisha
Rep Power: 6 |
How to import 'x-velocity' and 'y-velocity' data into Tecplot-360, and draw streamlines?
I am using a sliding mesh to simulate flow past a rotating elliptic cylinder in ANSYS. When I import the case & data file into Tecplot and try to draw the streamlines, they break at the interface of the stationary and rotating domain. I have attached an image of the problem I am facing. I am given to understand that importing just the 'x-velocity' and 'y-velocity' data will resolve this problem, but I don't know how to go about it. I'd be grateful if anyone could elucidate how to import the files, and what to do once they are imported in Tecplot. I viewed this video on youtube- "Tecplot 360 Interpolation". But when I tried it, my cylinder disappeared, so it wasn't much help. PS: I have Tecplot 360 EX 2014. |
July 18, 2021, 06:12 |
Sayan Bhattacharjee
Rep Power: 8 |
-deleted-
didn't read the question correctly before answering... apologies... |
July 18, 2021, 22:48 |
Kira
Rep Power: 8 |
What post processing software are you using (Fluent, CFX, etc...)?
July 19, 2021, 00:51 |
Odisha
Rep Power: 6 |
Hi, I'm using Fluent.
July 20, 2021, 02:43 |
Kira
Rep Power: 8 |
Okay, what format are you outputting the data as to Tecplot?
July 20, 2021, 05:53 |
Joern Beilke
Rep Power: 20 |
You can not do it with "Streamlines", because they have no meaning in a transient calculation. When you use the "absolute velocity" at a fixed time, the lines will usually hit the rotating wall, since in reality it has already moved.
Just do a transient particle tracking instead. Here is an example, that I did some time ago in EnSight (and also in StarCCM+) . But it should be also possible in Fluent. https://www.beilke-cfd.de/files/vide...umeco_1280.mp4 |
July 21, 2021, 08:20 |
Odisha
Rep Power: 6 |
I am loading the case and data file of Ansys Fluent 2019R3 into TecPlot 2014.
Getting divergence in dynamic mesh but not sliding mesh | niamhiefitz | FLUENT | 0 | April 20, 2021 06:08 |
Dynamic Mesh and Sliding Mesh Simultaneously | reynold92 | FLUENT | 2 | May 9, 2015 15:26 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
3D Hybrid Mesh Errors | DarrenC | ANSYS Meshing & Geometry | 11 | August 5, 2013 06:42 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 09:03 |
