July 26, 2021, 08:07 |
pressure velocity coupling
bhargav
why we are using the pressure velocity coupling when we use one continuity equation and three momentum equations to calculate the u,v,w,p for incompressible flows. we have four equations and four unknowns right..? then what is the need for pressure velocity coupling?
July 26, 2021, 09:00 |
#2 | |
July 26, 2021, 09:23 |
#3 | |
Filippo Maria Denaro
Rep Power: 71 |
I am not sure if your question is about the theoretical coupling for the incompressible flow model in contunuous form or you are asking for the numerical fomulations (that is why pressure or density-based solver) chosen to solve. |
July 26, 2021, 10:18 |
Lucky
Rep Power: 66 |
Pressure doesn't have its own independent equation where you can solve purely for pressure. Pressure appears in the momentum equation and is coupled with the velocity. They are coupled.
If you are asking why we need to use specifically SIMPLE to solve for pressure and velocity, you do not always have to use SIMPLE. You can use coupled solvers that solve simultaneously for pressure and velocity. |
viscosity udf don't use correct temperature and strain rate | rezvani | Fluent UDF and Scheme Programming | 8 | May 27, 2021 05:40 |
Fail to converge when solving with a fabricated solution | zizhou | FLUENT | 0 | March 22, 2021 06:33 |
Wind tunnel Boundary Conditions in Fluent | metmet | FLUENT | 6 | October 30, 2019 12:23 |
UDF comilation error. urgent help please | m zubair | Fluent UDF and Scheme Programming | 4 | February 10, 2019 11:19 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
