July 31, 2021, 13:48 |
Aliasing low frequency in Energy Spectrum
N/A
Rep Power: 5 |
I am running a case in a CFD LES software with implicit filter. Have you ever experienced an aliasing due to the grid? The spectra in frequency with a coarser grid seems to have bigger value of energy then the same case with a finer grid. Can this be due to an aliasing caused by the grid? |
July 31, 2021, 15:47 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
It could be an effect of aliasing (but what about your discretization of the non-linear terms?) but that could be one among other possible causes. Could you provide details of your simulation and post the figures of the two spectra? |
July 31, 2021, 17:04 |
N/A
Rep Power: 5 |
If I have an aliasing, is it possible that some terms that should have been counted as sub-grid scales, are instead counted in the lower frequency?
July 31, 2021, 17:10 |
#4 | |
Rep Power: 71 |
Aliasing means that the non-linear quadratic terms produce components behind the cut-off grid frequency, that is in the range of the unresolved terms. But do not forget that the SGS model by itself acts adding a contribution only on the lower resolved frequencies. Thus, also some problems in the SGS model could generate an increasing in the resolved energy level. Without details I cannot say more. |
August 12, 2021, 04:48 |
EM
Rep Power: 6 |
u r probably using finite differences which means aliasing from high wavenumbers is not an issue. also, the unpredictability of low resolution simulations based on truncation error for stabilization means that u must increase resolution 'sufficiently' before start considering fanciful alternatives.
also, yr domain may be too short but u have given shod-all info on yr simulation. -- |
August 12, 2021, 05:18 |
#6 | |
Rep Power: 71 |
"using finite differences which means aliasing from high wavenumbers is not an issue" why do you wrote that? |
How to plot time dependent energy spectrum | Falu | Main CFD Forum | 21 | January 16, 2021 08:41 |
Cumulative energy spectrum | bhigahAshish | Main CFD Forum | 4 | April 11, 2020 09:11 |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 15:45 |
turbulent energy spectrum | cfd.newbie | Siemens | 1 | June 19, 2008 23:48 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
